something inside the cv boot disconnected and won't go back into place
Old Feb 15, 2004 | 08:19 PM
AzntaggeR's Avatar
TSPeed Factory
Default something inside the cv boot disconnected and won't go back into place
alright i'm trying to put the driver side axle in, and something inside the cv boot is not wanting to go back into place. because it doesn't go back into place my front LCA won't line up with the holes to bolt it back in. is the axle just going bad or am i just doing something wrong?
this is for a B18C1 motor if that helps.
Old Feb 15, 2004 | 08:22 PM
Turbogixxer's Avatar
Default Re: something inside the cv boot disconnected and won't go back into place (AzntaggeR)
You probably pulled the axle hard enough to pull the bearings in the axle out. You may have to take the boot off and put the bearing back in place.
Old Feb 15, 2004 | 08:24 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: something inside the cv boot disconnected and won't go back into place (turbogixxer)
is that hard to do? i've never replaced the cv boots before.
Old Feb 15, 2004 | 08:27 PM
compwc18's Avatar
CV boot's arent hard but they are annoying... when i was swapping a B16a into my car, the CV boot broke and i had to replace it...
IWearMyKswiss's Avatar
New User
id rather get a new axle than trying to fix that one
Old Feb 15, 2004 | 08:28 PM
Mar_DC2's Avatar
Default Re: something inside the cv boot disconnected and won't go back into place (compwc18)
same thing happened to me when i changed a CV boot. just put the bearing back together and youll be fine.
Old Feb 15, 2004 | 08:29 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">is that hard to do? i've never replaced the cv boots before.</TD></TR></TABLE>
It takes time. What I do is set the bearings up (you will see how they go) and spin the bearing and see if it fits, then repeat until it "falls" in. You do not have to hammer them in, they will fall into place.
B18CivicEH2
Mar 19, 2007 05:13 PM
B18CivicEH2
Mar 19, 2007 03:13 PM
bab33face
Oct 22, 2006 01:45 PM
gtowni3
Dec 24, 2004 08:09 AM
