89 Honda Tranny Drop... I cant get it out..any thoughts?
Old Feb 15, 2004 | 04:07 PM
Rocker's Avatar
Default 89 Honda Tranny Drop... I cant get it out..any thoughts?
I got an 89 Honda accord DX with some bad clutch plates. I am trying to drop the tranny so that I can pull it apart and change the plates. I have done everything I need to do to make room for the pull and have pulled of a **** load of mounting bolts. OR so I thought cause I cant get that thing to seperate from the engine. I move it up and down and its still one big piece. I cant see any other bolts and I am not sure how violent I got to get when it comes to prying it loose. I am assuming that there is one more bolt somehwere or somthing seeing that little to no space is made when i try to pry. Got any ideas let me know cause I am stuck. thxs
Late
Old Feb 15, 2004 | 04:48 PM
cd555's Avatar
Default Re: 89 Honda Tranny Drop... I cant get it out..any thoughts? (Rocker)
Check out http://www.3geez.com they might know over there.
Old Feb 15, 2004 | 05:03 PM
ArchAngel Sabastian's Avatar
New User
theres bolts on the backside kinda like behind the rear mount, the tranny should be able to spin be turned by hand independant of the engine so if your turning it and its still moving the whole motor you missed something, just work your way around the entire bell housing untill you get everything.
Old Feb 15, 2004 | 05:21 PM
88LXi68's Avatar
Default Re: (ArchAngel Sabastian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ArchAngel Sabastian &raquo;</TD></TR><TR><TD CLASS="quote">theres bolts on the backside kinda like behind the rear mount, the tranny should be able to spin be turned by hand independant of the engine so if your turning it and its still moving the whole motor you missed something, just work your way around the entire bell housing untill you get everything.</TD></TR></TABLE>
Like he said... there are I think 2 bolts that come from the opposite side. One is on the lower small L shaped looking mount, the other goes through the block.
Old Feb 15, 2004 | 09:39 PM
90Ninja
Guest
Posts: n/a
Default Re: (88LXi68)
I think also on the bottom next to the oil pan there is a clutch dust cover. You have to get that off to pull the tranny apart from the block.
jdm702
Transmission & Drivetrain
May 18, 2010 09:27 PM
Alpinestar03
May 11, 2007 04:26 PM
triggerX
Apr 24, 2004 12:03 AM
shortyz
22
Jan 4, 2003 01:39 AM
spladam02
Dec 8, 2002 06:42 PM
