hey!!! NEONE HERE got an F20B engine ? F20b or F20B2 ... IMPORTANT!
Old Oct 10, 2001 | 07:10 AM
JinMTVT's Avatar
New User
Default hey!!! NEONE HERE got an F20B engine ? F20b or F20B2 ... IMPORTANT!
ok!
do you guys with F20b engine ever thought of tryin H22a head parts in your engine ?
there are almost no engine tunning parts avaible for any F20b from what i know..
and with mugen that dropped development for this engine few years ago ..
so ..ithe F20 and H22a have a lot in commmon, they bolt on samme place, the trannys are swappable, do you guys ver thought of tryin engine parts from H22a ?
I'm pretty sure that if it fits, Euro R or type S cams from H22a would be of a great benefit ... and if it fits..that would also means that CROWERs and JUNs H22a cams
would work entering there a custom illimited possibilities..
then, did u know that with proper settings, the F20B2 can rev as high as B16/18 tunned
yes that means 10 000+ RPM..and that also means alot of power.
i would also like a lot to see a dyno plot from a F20B engine..just for info and to check out how the torque goes ..
what do u guys think ? neone ever tried such things ?
Old Jul 7, 2013 | 01:11 AM
Acc93_vn's Avatar
Default Re: hey!!! NEONE HERE got an F20B engine ? F20b or F20B2 ... IMPORTANT!
Hi , i am ower a accord 94 with F20b2 engine, now it run well, I think all of the engine of Honda (or accord only) are common part spec. what do you need with your engine ? pls detail if i can then help you,
Hi all Expert Honda,
help me, I could not find any oxy sensor on my Accord 94 with Engine F20b2, Who can help me ? why honda didnot install Oxy sensor ? so how to control fuel close foop?
thanks very muck
Mr Drew
Old Jul 7, 2013 | 01:47 AM
holmesnmanny's Avatar
just get an h22a oxygen sensor....they will work just the same..just make sure it's a Denso sensor and it will need to either be female or male depending on your car...they do make both
Old Jul 7, 2013 | 02:06 AM
NZXTInerTia's Avatar
thanks very muck
Mr Drew
1. You must be foreign, but I can not understand ANYTHING you just said. I think you were asking where it is? But I'm not sure.
2. Make your own thread! This post is literally 12 years old, let her die.
jnate189
Oct 3, 2007 07:10 AM
diarrik
Mar 19, 2007 06:51 PM
nelsond
Sep 24, 2005 07:20 PM
