ZC - timing cover hits the hood on EF hatch?
Old Feb 15, 2004 | 08:42 AM
ham's Avatar
ham
Default ZC - timing cover hits the hood on EF hatch?
i was told by alot of people that i have to get the hood with the bulge in it, or my hood will hit the timing cover, which will cause it to hit the belt.
I haven't noticed anything rubbing, has anybody else gotten away with it?
Old Feb 15, 2004 | 08:43 AM
crxgator's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (zcNOS)
didnt rub on either of my cars that had em...
Old Feb 15, 2004 | 09:27 AM
FourthGenHatch's Avatar
I think you will be ok without it.
Old Feb 15, 2004 | 10:29 AM
4potnick's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (FourthGenHatch)
no rubbing on my crx.
Old Feb 15, 2004 | 12:15 PM
blah13's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (4potnick)
Mine doesnt rub also.
Old Feb 15, 2004 | 12:21 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: ZC - timing cover hits the hood on EF hatch? (blah13)
mine didn't have the top half of the timing cover on it. and the belt never rubbed.
Old Feb 15, 2004 | 12:23 PM
ek_99_SiR's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (LudeEFv2.0)
it wont rub... but if it does put washers under ur motor mount. ez fix
Old Feb 15, 2004 | 07:56 PM
civais's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (1.6i-16zc)
Just check on it every now and then to make sure your clear.
1. Remove top portion of timing belt cover. 2, Cut out a small piece of your hood frame. 3. Washers under your motor mounts.
Old Feb 15, 2004 | 09:40 PM
t0eKnEe's Avatar
https://honda-tech.com/zerothread?id=561914
Got tired of running around without the timing belt cover, and didnt feel like putting washers under my mounts.
Old Feb 15, 2004 | 09:44 PM
Disco_Stu's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (t0eKnEe)
I had to put a STACK of washers in my motor mount for the DOHC ZC to fit in my old 91. It worked fine after that. Some folks need to, while others don't.
Old Feb 15, 2004 | 10:18 PM
CRX-RX's Avatar
Default Re: ZC - timing cover hits the hood on EF hatch? (Disco_Stu)
Mine rubbed with a carbon hood and pretty new mounts, I think alot has to do with what condition your mounts are in. Anyways, If you cut the underside support about 5-6" above where it rubs should be fine after that.
bwebb111076
Aug 11, 2008 03:34 AM
spikehead221
Apr 2, 2008 12:05 PM
732xghost
Sep 9, 2007 10:02 AM
D21X
Sep 21, 2004 09:09 PM
noble4ws
Nov 11, 2003 05:27 AM
