tach install problem
Old Feb 15, 2004 | 08:06 AM
neutron91's Avatar
Default tach install problem
i recently installed an autometer tach in my friends civic... well everything is fine except the tach will not read properly... i clipped the blue loop on the back of the tach via the instructions... it reads about 3500 at idle and if you tap the gas it buries the needle... it was also brand new... i know i hooked it up correctly but i cant figure out whats wrong... anyone have any ideas??
Old Feb 15, 2004 | 08:50 AM
HatchBox's Avatar
Skoobie no more...
Default Re: tach install problem (neutron91)
on most tachs there is setting fors for 4 cyl, 6 cyl, and 8 cyl. it should be in the back of the trach and this is somehting like 4 switchs that have to be in the right order for what cyl engine you have.
what kind of tach is it?
Old Feb 15, 2004 | 09:40 AM
4DRPIMPIN's Avatar
Default Re: tach install problem (Hybrid Hatchback)
Yeah if it is autometer you should have to clip all the loop wires behind the tach..
Old Feb 15, 2004 | 09:45 AM
allicedout's Avatar
Ya i installed a Autometer. Clip all the wires in the back.
Old Feb 16, 2004 | 10:42 AM
neutron91's Avatar
Default Re: tach install problem (allicedout)
i tried clipping all the wires in the back... did the same thing... but we figured it out... turns out he has one of those autozone dizzys and im guessing the colors of the wires are different... we started tapping into different wires and we found one that worked perfectly fine... i originally had it tapped into the usual blue wire... what i found odd was that it still functioned while tapped into the blue wire even though the reading was way off... oh well atleast its fixed
Old Feb 16, 2004 | 10:57 AM
tgreaves's Avatar
The tach wire on the obd1 dizzy(possibly obd2 also) is on the 2 wire plug.. Its the smaller of the 2..
stanzione88
Oct 4, 2008 01:18 PM
hondaciv5
Honda Civic (2001 - 2005)
11
Nov 16, 2007 08:47 PM
CLE
12
Oct 31, 2007 07:31 PM
c_buz
Jan 19, 2005 05:58 PM
DarkBB4
Sep 25, 2004 09:41 PM
