my type r is making a funky noise anyone know what it could be?
Old Feb 14, 2004 | 09:07 PM
TypeR15's Avatar
Default my type r is making a funky noise anyone know what it could be?
hey, everytime i turn the wheel all the way you will hear a loud squeeky screech noise, anyone know what that could be? i just put my exhaust in today cant be that?
Old Feb 14, 2004 | 09:20 PM
kingK's Avatar
Default Re: my type r is making a funky noise anyone know what it could be? (TypeR15)
check cv boot
Old Feb 14, 2004 | 09:21 PM
TypeR15's Avatar
anybody thinks i need to put grease on the rubber boot that connects the tie rod to the suspension?
Old Feb 14, 2004 | 09:24 PM
kingK's Avatar
does your car have arond 60k miles
Old Feb 14, 2004 | 09:26 PM
TypeR15's Avatar
Default Re: my type r is making a funky noise anyone know what it could be? (kingK)
yes thats exactly how many miles my car has! im acually about to bring it in for a 60k checkup
Old Feb 14, 2004 | 09:27 PM
kingK's Avatar
ya i would change cv boot
Old Feb 14, 2004 | 09:30 PM
TypeR15's Avatar
change it u think? ill check it out in the am, shouldnt be anything bad right? just throw grease on it or change it?
Old Feb 14, 2004 | 09:35 PM
kingK's Avatar
change it i had same problem and didnt chang mine kept putting it off and snaped wheel bearing it is just worth replacing sve some money in long run
Old Feb 14, 2004 | 09:36 PM
TypeR15's Avatar
aight thanx a lot for your help man
Old Feb 15, 2004 | 06:50 AM
Jay J's Avatar
Prince of Zamunda
CV boots(do both at the same time) and Since it's due for the 60k service anyway might as well do the [Nothing to do with the problem but it's about time for it] Timing belt (for 60k miles) You could wait till 65).. and repack front wheel bearings
Old Feb 15, 2004 | 07:13 AM
1GreyTeg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingK &raquo;</TD></TR><TR><TD CLASS="quote">ya i would change cv boot</TD></TR></TABLE>
Why, if it's not torn or showing any sort of wear?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kingK &raquo;</TD></TR><TR><TD CLASS="quote">does your car have arond 60k miles</TD></TR></TABLE>
Since when does mileage have anything to do with mandated CV boot changing?
Checking it for wear or damage for certain but, just stating to change it because you think that it's the cause of his vague description of a problem is silly.
If his CV joint (not boot, which are 2 different things) is damaged then changing the CV boot will do nothing in saving his axle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TypeR15 &raquo;</TD></TR><TR><TD CLASS="quote">aight thanx a lot for your help man </TD></TR></TABLE>
I wouldn't be so quick to thank for his help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">CV boots(do both at the same time)</TD></TR></TABLE>
Do both? Why, if they are not damaged? I think you're confused a bit. Do you know what's even involved in doing them (inners and or outers)? Rhetorically of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote"> and Since it's due for the 60k service anyway might as well do the [Nothing to do with the problem but it's about time for it] Timing belt (for 60k miles) You could wait till 65)</TD></TR></TABLE>
Huh? Since when do we need to change the Timing belt at 60 or 65,000 miles? When the heck did this happen? Uhhh NO! Not till 90,000 on the 94 to 97 Integras and between 100,000 to 105,000 for the 00 and 01's from what I remember from the Helm's manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neuspeed &raquo;</TD></TR><TR><TD CLASS="quote">.. and repack front wheel bearings</TD></TR></TABLE>
I'd look up Willard's post regarding this for a clear description and pictures of this.
https://honda-tech.com/zerothread?id=720159
Where did all the misinformation come from?
Let's go back to original posters problem. Did it make a clicking, grinding, screeching? I mean it's hard enough to do it this way online but, for God's sake don't just arbitrarily change CV boots for what, the fun of it.
Modified by 1GreyTeg at 8:44 AM 2/15/2004
Old Feb 15, 2004 | 07:22 AM
RTW DC2R's Avatar
Default Re: my type r is making a funky noise anyone know what it could be? (1GreyTeg)
I agree with 1Greyteg. There are other things to check before replacing a CV boot. And unless the CV boot is damaged or leaking, or the axle itself is damaged, I dont see any reason to replace them. Does the squeaking happen only when cold outside? Do you have any suspension changes other than stock? Id probably start by checking power steering fluid, belts, and then bushings in the front suspension.
Timing belt at 60k?? Is that what the manual says(I dont have a manual)?? Personally I wouldnt bother replacing that yet unless it looks like its worn and needs to be replaced. Thats a lot of work to be done when you just have a squeak somewhere, so Id check everything else first.
magic hat #9's Avatar
what size wheels and tires are you using? offset of wheels? lowered? it sounds more like his tires are rubbing on full lock. wouldn't a busted cv joint be more of a knocking sound and give feedback through the steering wheel?
Old Feb 15, 2004 | 07:31 AM
1GreyTeg's Avatar
Default Re: my type r is making a funky noise anyone know what it could be? (magic hat #9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by magic hat #9 &raquo;</TD></TR><TR><TD CLASS="quote">what size wheels and tires are you using? offset of wheels? lowered? it sounds more like his tires are rubbing on full lock. wouldn't a busted cv joint be more of a knocking sound and give feedback through the steering wheel?</TD></TR></TABLE>
Yeah, and even from his description he could have even had a rock or crap stuck between his brake pad and rotor for that moment. Who knows,,, there are a few more than just one answer here for the description and definitely Not just change CV boots.
Old Feb 15, 2004 | 08:05 AM
b19coupe's Avatar
How is your power steering belt tension?
Old Feb 15, 2004 | 09:38 AM
Default Re: my type r is making a funky noise anyone know what it could be? (b19coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">How is your power steering belt tension?</TD></TR></TABLE>
yeah, could be your power steering belt slipping, but it would probably do it everytime you turn the wheel, not just at lock.
Modified by magic hat #9 at 5:07 PM 2/15/2004
Old Feb 15, 2004 | 12:54 PM
itRgirl's Avatar
is it when the car is stopped or just when it moving?
Old Feb 15, 2004 | 07:21 PM
TypeR15's Avatar
Default Re: my type r is making a funky noise anyone know what it could be? (itRgirl)
its louder when im stoped but also does it when im moving, i didnt get a chance to look at it yet but its still there
Old Feb 15, 2004 | 07:25 PM
r573's Avatar
would be good to start with the small things like the power steering fluid
Secret Chimp
Feb 9, 2008 01:27 PM
scott1ct
Jun 11, 2007 05:43 PM
tigueremalo
Jul 14, 2006 04:28 AM
Matgallis
Feb 20, 2004 07:21 AM
machgo5go
Sep 13, 2002 04:05 AM
