What is Easiest way to Bleed your break system?
Old Oct 9, 2001 | 05:32 PM
nsx-Animal's Avatar
Default What is Easiest way to Bleed your break system?
Hey guy's what is the easiest way to bleed your break system? I want to get rid of the stock fluid and put some Motul brake fluid in my R.
Thanks
Old Oct 9, 2001 | 05:34 PM
yoshi234's Avatar
I shoot brides
Default Re: What is Easiest way to Bleed your break system? (ITR-Animal)
i'm gonna try and make my own pressure bleeder
http://www.bmw-m.net/TechProc/bleeder.htm
Old Oct 9, 2001 | 05:38 PM
Willard's Avatar
Default Re: What is Easiest way to Bleed your break system? (yoshi234)
Looks like a plan Y-b0t.
Animal maybe try a set of these. http://www.speedbleeder.com/
Willis
-who hopes you brake system does not break
[spelling]
[Modified by Willard, 9:38 PM 10/9/2001]
Old Oct 9, 2001 | 05:47 PM
MintyDip's Avatar
Default Re: What is Easiest way to Bleed your break system? (Willard)
Find a monkey to help you out
perhaps dr vtec can help you on this one
Old Oct 9, 2001 | 05:51 PM
travis's Avatar
Default Re: What is Easiest way to Bleed your break system? (MintyDip)
I just picked up one of these:
from here:
http://www.motiveproducts.com/ordernow_bleeders.htm
Old Oct 9, 2001 | 05:58 PM
Willard's Avatar
Default Re: What is Easiest way to Bleed your break system? (ITR#231)
Daym...
I thought is was one of those MONDO-sized Swedish "pump" things.
Looks like anothe plan.
will
-who liked Austin Powers.
Old Oct 9, 2001 | 06:03 PM
travis's Avatar
Um, it is...
What were we talking about again?
[Modified by ITR#231, 7:05 PM 10/9/2001]
Old Oct 9, 2001 | 06:08 PM
EPGONZALEZ's Avatar
the old school way of pumping the brake pedal isnt very good and could damage your master cylinder..i rec. the mighty vac...that swedish ***** inlarger might work too..
Old Oct 9, 2001 | 06:18 PM
nsx-Animal's Avatar
Default Re: What is Easiest way to Bleed your break system? (EPGONZALEZ)
Thanks guys very helpfull....
Old Oct 9, 2001 | 06:23 PM
AdamITR's Avatar
If you have a friend that can help, it can be done pretty quickly. You don't need to spend extra cash on the above items.
The Professional's Avatar
New User
The absolute easiest way to do it is with a buddy on the side. 2 people get the job done right a lot faster than you can w/ the bleeder system.
Old Oct 9, 2001 | 06:37 PM
b00st-0wnz's Avatar
From: Drinking Beer in sunny FL and jamming to Skid Row, USA
ITR-Animal: I use a vacuum system that's connected to a compressor. Expensive but works damned well. Otherwise, I just have someone pump the brakes while I do the bleeder screw.
Old Oct 9, 2001 | 06:47 PM
R748's Avatar
The "old school" way is the best way (and I've gone through hell trying to bleed the ITR system - trust me) if done right. You're absolutely right that one could damage the seals in the master cylinder if you press the pedal ALL the way in during the bleed. However, it's a mistake to do so anyway.
My best combo : old method + one way bleeder (a.k.a speed bleeder), fast and seems to work well. Be careful, as some bleeders do leak along the threads. A little plumbers tape on the thread fixes it right up.
I've read the pressure bleeders tend to cause aeration and hence introduce bubbles into the system. I'm not sure if this is true or not.
[Modified by R748, 7:49 PM 10/9/2001]
Old Oct 9, 2001 | 09:57 PM
Zeus's Avatar
Default Re: What is Easiest way to Bleed your break system? (R748)
What's the part number on the ITR f/r calipers again?
Old Oct 9, 2001 | 10:04 PM
Mike M's Avatar
Founding Member
Default Re: What is Easiest way to Bleed your break system? (Zeus)
Courtesy of D's and Aleph's Page
"you'll need two pairs of the SB10125 for the brakes, and it can't hurt to get an SB8125L for your clutch slave cylinder"
civic_driver
18
May 26, 2010 08:22 AM
93sivtec
May 18, 2007 05:42 AM
ACIN
Jan 27, 2002 09:32 AM
Flux
Oct 6, 2001 10:55 AM
