Honda S2000 Honda S2000
S2000 OEM muffler inlet diameter
Old Feb 13, 2004 | 02:25 PM
TheGSRGuy's Avatar
Default S2000 OEM muffler inlet diameter
Can't seem to find the answer anywhere, and the guys on S2KI.com didn't even reply: what is the inlet diameter on the OEM S2000 muffler? I've heard 2" from some people and 2.25" from others.
Old Feb 13, 2004 | 05:06 PM
evil vapor's Avatar
Default Re: S2000 OEM muffler inlet diameter (TheGSRGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheGSRGuy &raquo;</TD></TR><TR><TD CLASS="quote">Can't seem to find the answer anywhere, and the guys on S2KI.com didn't even reply: what is the inlet diameter on the OEM S2000 muffler? I've heard 2" from some people and 2.25" from others.</TD></TR></TABLE>
hrm, I'll go measure it later tonight. Since it's metric, I should be closer to 2.25" why do you need to know the exact measurements? The muffler isn't light.
Old Feb 13, 2004 | 05:16 PM
TheGSRGuy's Avatar
Default Re: S2000 OEM muffler inlet diameter (vapor)
I'm interested in retrofitting one to my GS-R. I read that the pipe is 57.2mm, but others have said it is closer to 51mm. I'm also curious about what the dimensions of the muffler itself are. Thanks a lot.
Old Feb 13, 2004 | 05:45 PM
evil vapor's Avatar
either way, it'll work, are you using muffler clamps or are you getting it welded?
Old Feb 13, 2004 | 06:15 PM
TheGSRGuy's Avatar
No clue yet. I just want to make sure this is feasible before I go searching for the muffler.
I'm currently running an ITR b-pipe+ITR muffler...I want to know if it is 2.25 because that way I can sell the ITR muffler but keep the b-pipe.
realis9
Jan 15, 2010 10:27 PM
truelaostha
Mar 22, 2004 10:40 AM
k_spek
Honda S2000
Jan 30, 2004 07:02 AM
EL-Driver
Honda S2000
Jan 20, 2003 03:08 PM
