motor + oil catch can pics - if anyone cares
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eluder200K »</TD></TR><TR><TD CLASS="quote">
LMFAO, that's great
</TD></TR></TABLE>LMFAO, that's great
You posted the link while logged in on your account on the RSX board, that's why no one else can see them, you need to copy a link while not logged in.
I think
I think
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98cwitr »</TD></TR><TR><TD CLASS="quote">working?</TD></TR></TABLE>
not yet. try to save them to WTDR
Is it a good idea to having the hose as the lowest part of the oil catch system?
I'd monitor the hose to ensure it does not get plugged with a pocket of oil.
I'd start off by hooking the catch can up the proper way , after that I'd ditch that aquarium hose that collapses under heat.
you also want the can lower than the PCV valve so that oil doesnt sit in the tubes and gunk up the whole system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ »</TD></TR><TR><TD CLASS="quote">I'd start off by hooking the catch can up the proper way
The "proper" way:
And the end result after 45 minutes of hard track time:
The "proper" way:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">
Dang that's a good bit of oil, but mine goes through that in 45 minutes of highway driving
I bet its nice knowing that you aren't burning all of that through the engine now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ »</TD></TR><TR><TD CLASS="quote">I'd start off by hooking the catch can up the proper way , after that I'd ditch that aquarium hose that collapses under heat.
what he said.. you can run baffled or you must run baffled if you want another can for breather valve.. but with what you have.. you might end up doing some damage from what i read.. that air from valve cover breather may not have much room to go to
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor CorteZ »</TD></TR><TR><TD CLASS="quote">you also want the can lower than the PCV valve so that oil doesnt sit in the tubes and gunk up the whole system.</TD></TR></TABLE>
It's been a while since I've seen a stock PCV setup, but isn't the PCV located on top of the oil collection "box" at the bottom of the block? From there, oil vapor flows straight up to the IM, correct? Why would one want to hook up a catch can below the PCV? My baffled catch can sits up high, and has a return hose that returns condensed oil back to the block.
wtf? i see them
