if you have h22 swap....can u go back to b-series...in your eg
Old Feb 13, 2004 | 11:55 AM
gdrum's Avatar
Default if you have h22 swap....can u go back to b-series...in your eg
if you have h22 swap....can u go back to b-series...in your eg ?
Old Feb 13, 2004 | 12:01 PM
Jimmy's Avatar
Global Moderator
Are you referring to like all of the major work that is done.. with fender wells ,etc?
If so good question!
Someone answer this one for us.
Old Feb 13, 2004 | 12:03 PM
splitime's Avatar
Default Re: if you have h22 swap....can u go back to b-series...in your eg (gdrum)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gdrum &raquo;</TD></TR><TR><TD CLASS="quote">if you have h22 swap....can u go back to b-series...in your eg ?</TD></TR></TABLE>
I'd guess yes. But you'll be welding or bolting new pieces of metal to your shifter area at the least (capping off the holes made for shifter and cables).
Old Feb 13, 2004 | 12:04 PM
slammed_93_hatch's Avatar
Default Re: (USDMDC2)
well there is some cutting done. but **** i guess it could always be fixed up and redone
Old Feb 13, 2004 | 12:05 PM
POE's Avatar
POE
yeah cause u got to do some cuttin when u install the diffrent tranny... good question
Old Feb 13, 2004 | 12:32 PM
gdrum's Avatar
Default Re: (Vtecin94dx)
the only parts on my that is cut is the engine mounts cut back.....and the shifter is cut out....but i figure the mounts prob still work......and just put a weld in a sheet where plate was and put old shifter back in...or something.......
Old Feb 13, 2004 | 02:20 PM
gdrum's Avatar
bump
Old Feb 13, 2004 | 02:45 PM
JDMH22HATCH's Avatar
Yes you can, and a few member's on these boards have done so. Part of it depends on what mounts you uses, but either way, you can go back to a b-series. With the HCP mount, you trim the factory tranny mount bracket and redrill for the new mount. For the Hasport mounts, you actually remove the factory tranny mount bracket. If you ran these, you would have to get another one and retack and weld it back onto the frame. As for the shift linkage, you could easily rivet some aluminum or sheet metal to cover that hole, and depending on how much you cut and trimmed for the shifter, depends on how much you would need to patch up if any. But to answer your question, yes, it is possible and I have seen b-series hatches that were previously H-series. Good luck
colin00si
Aug 14, 2008 07:09 PM
VTECengaged
Dec 30, 2007 07:34 AM
Novtecdohc
Jan 6, 2007 06:29 PM
soon2b
Feb 5, 2005 09:43 AM
CrVtec122
Jun 7, 2004 12:05 PM
