putting a 900 motor on my 600?????????
Old Feb 13, 2004 | 07:51 AM
redhatchb18's Avatar
Default putting a 900 motor on my 600?????????
who has done the conversion on there bike? i have a 2001 600 f4i and want to put a 900 motor on it. is this possable and what all is needed to do this?
Old Feb 13, 2004 | 08:23 AM
SLATER97EX's Avatar
Default Re: putting a 900 motor on my 600????????? (babyboib16)
You would have to fabricate a kit, none of the 900 motors would just bolt right up....And the 900 motors use carbs, so I'm not even sure that motor would fit on that frame....
Old Feb 13, 2004 | 05:00 PM
Duster's Avatar
yeh its not going to install right in, it would be alot of work ...just buy a 900
Old Feb 14, 2004 | 07:23 AM
busa1300's Avatar
I have seen it done before. If you are doing it to save weight then look at somthing else, the opne I had seen had a total weight savings of under 10Lbs. And the 900's chassie is much stuffer and designed for the Hp and Torque.
Old Feb 16, 2004 | 11:19 AM
BoostedSi's Avatar
Default Re: putting a 900 motor on my 600????????? (busa1300)
heres an f2 with a 900rr motor
http://cgi.ebay.com/ebaymotors...49999
Old Feb 17, 2004 | 05:09 AM
Default Re: putting a 900 motor on my 600????????? (BoostedSi)
yea i see people doing it all the time with the older f2's and f3's. i also see it alot with the old 750's putting 1100 motors in. i dont know if i am going to try to do it if it will be to much work i just wanted to see it i could do it cause i had a guy give me a good deal on a 900 motor and tranny and i was going to get it if it could be done.
Old Feb 17, 2004 | 06:10 AM
quickergixxer's Avatar
just my opinion but that f2 frame on the link above dosent look near as strong as the one on my 98 750. i would take a close look at the 900 frame im sure its much stronger
Old Feb 17, 2004 | 06:40 AM
busa1300's Avatar
7/11 swaps were easy, it was almost just a direct swap a cbr 600/900 is not quite a bit more fabracation. But almost anything can be done with enought time and money, if lee can shoe horn a busa motor into a GSXR 600 frame. The frame in the ebay bike it toasted, it will never be right and the cast aluminum motor mount that broke off the engine can't be repaired right. You can weld cast aluminum for those applications.
Old Feb 18, 2004 | 05:05 AM
well it sounds like a little to much work for me right now. mabey i will just try to see if i can find one for sale.
Old Feb 18, 2004 | 11:51 AM
Duster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by babyboib16 &raquo;</TD></TR><TR><TD CLASS="quote">well it sounds like a little to much work for me right now. mabey i will just try to see if i can find one for sale.</TD></TR></TABLE>
hahah thats the spirit..
.Ash
Honda Motorcycles
25
May 8, 2006 05:02 PM
e2000
Honda Motorcycles
10
Sep 7, 2005 10:53 AM
JDMCRX
Honda Motorcycles
May 31, 2005 10:34 AM
Showoff
Honda Motorcycles
Jan 15, 2005 07:38 PM
