D Series Tranny Questions
Old Feb 12, 2004 | 10:45 PM
xerox445's Avatar
Default D Series Tranny Questions
Will a D series trans fit on a SOHC ZC motor in a crx? For example a d16z6 trans on the sohc ZC. Thanx in advance
Old Feb 12, 2004 | 10:48 PM
89dxhunchback's Avatar
Default Re: D Series Tranny Questions (xerox445)
No. The 92'+ trannies have different motor mount points on top of being hydro, not cable. The cable part is fixable, but the mounts would just be dumb to fab-up.
Old Feb 12, 2004 | 10:52 PM
xerox445's Avatar
Default Re: D Series Tranny Questions (89dxhunchback)
so what kind of trans should i look for for a sohc zc motor. Its for a friend, so im lost with this EF stuff, im a EG guy.
Old Feb 12, 2004 | 11:32 PM
91civicEX's Avatar
if the motor is in an EF then use any cable D series tranny. basically anything out of an 88-91 civic, crx, and 2wd wagon. yep that sums it up i think. oh yea
if the car is and 88 you can only use and 88 tranny with the 88 flywheel. 89-91 you can mix around. if you already have the tranny off upgrade to a 90-91 clutch and flywheel. (more surface area=more grabbing ability)
eg2jr
Jan 12, 2009 07:06 AM
trex352
Feb 2, 2007 05:51 PM
jetpilot
May 22, 2004 11:46 PM
Doug684
14
Oct 1, 2003 01:11 PM
ahc'monracing
Feb 5, 2003 06:34 AM
