would 2000 civic skunk2 short shifter work on 93 eg sohc??
Old Feb 12, 2004 | 06:43 PM
egturbo's Avatar
Default would 2000 civic skunk2 short shifter work on 93 eg sohc??
hey wassup guyz like the title says. would a 2000 ex civic skunk2 short shifter work on my 93 civic with sohc? TIA
Old Feb 12, 2004 | 06:44 PM
diearzte2
Guest
Posts: n/a
What motor/transmission? It depends on the Shift linkage which depends on the motor/tranny.
Old Feb 12, 2004 | 07:25 PM
egturbo's Avatar
Default Re: (diearzte2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by diearzte2 &raquo;</TD></TR><TR><TD CLASS="quote">What motor/transmission? It depends on the Shift linkage which depends on the motor/tranny.</TD></TR></TABLE>
i got the 2000 ex d16y8 motor/tranny/shiftlinkage in my 93 civic hatchback. hope that helps
Old Feb 12, 2004 | 07:39 PM
Echo7847's Avatar
Default Re: (egturbo)
Yes it will, the shifter fits 92-00 civic's
Old Feb 12, 2004 | 08:21 PM
egturbo's Avatar
Default Re: (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it will, the shifter fits 92-00 civic's</TD></TR></TABLE>
thats what i thought. but when i shift its like hard to get in gear. bad installation maybe? what can it be. well 1st goes in fine 2nd fine but 3rd when u try to downshift it'll be hard to go in and when it does it grinds sometimes in 4th also. its not the tranny. tranny is good with no grinds.
Old Feb 13, 2004 | 06:19 PM
nub's Avatar
nub
Default Re: (OOsi)
just a guess but maybe the bolt holding the shifter to the shift rod is to tight. whith the engine off or on and clutch in does the shifter seem stiff or harder to move compared to before the install? if so loosen the nut/bolt holding the shifter to the shift rod.
Old Feb 13, 2004 | 08:31 PM
egturbo's Avatar
Default Re: (nub)
yeah ill try that.
hey what bout shift linkage? its a complete 2000 ex sohc cahnge over with shiftlinkage also. they should fit right?
forsakenangel13
Aug 19, 2016 07:37 AM
zoso
Oct 7, 2007 10:39 AM
efyou
Sep 22, 2005 03:35 PM
jay.dee.em1
11
Dec 17, 2004 11:29 AM
kwatch
Sep 30, 2004 09:37 AM
