Do cams make a distinct sound when reving your car?
Old Oct 9, 2001 | 12:29 PM
duduvr6's Avatar
New User
Default Do cams make a distinct sound when reving your car?
anybody?
Old Oct 9, 2001 | 12:37 PM
1GreyTeg's Avatar
Default Re: Do cams make a distinct sound when reving your car? (duduvr6)
Different cams make different sounds, just like different engines make different sounds, like different mods make different engines sound differently.
Do you mean Stock cams as opposed to aftermarket cams? amd do you just mean cams or the combination od cams and I/H/E or just H&E or just E?
Your's is a broad question,
A.
Old Oct 9, 2001 | 12:38 PM
Black SVT's Avatar
Default Re: Do cams make a distinct sound when reving your car? (1GreyTeg)
I know if you don't have cams it quites the car down a lot
Old Oct 9, 2001 | 12:47 PM
Big Phat R's Avatar
Mine go:
Bwwwwwwwwwwwaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhh(vte c)BWWWWWWWWWWWAAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHH HHHHHHHH!
Old Oct 9, 2001 | 01:30 PM
Mike K's Avatar
Default Re: Do cams make a distinct sound when reving your car? (Big Phat R)
I can tell you that Toda Spec A cams "pop" louder when they go into VTEC.
The Crower cams are loud as hell when they go into VTEC because the VTEC lobes are much larger than the primaries.
This same aspect can be seen in the Spec B cams, but in the opposite way.
It's hard to tell when VTEC kicks on the Spec B's because the low lobes are so big and the powerband is so linear.
But yea, when a car has Spec B's and it's full throttle, you can tell the car has some sack.
Angel4768
May 23, 2011 09:49 PM
SD_EM1
Oct 19, 2004 12:31 PM
Drag-On
Feb 29, 2004 06:06 PM
neo1z
Apr 15, 2002 06:23 PM
