Yay!! Suspension parts FINALLY came in!!
Old Oct 9, 2001 | 12:25 PM
Dru-Si's Avatar
Default Yay!! Suspension parts FINALLY came in!!
Yup, it's about time! 4 weeks but well worth the wait I guess. Pics will be up later this week.
H&R sport springs
Koni Red shocks
So how do I adjust the shocks?
Old Oct 9, 2001 | 08:12 PM
Dru-Si's Avatar
Default Re: Yay!! Suspension parts FINALLY came in!! (Dru-Si)
Ummmmm......
So no one on here has Koni Reds??
Old Oct 9, 2001 | 11:47 PM
martini's Avatar
I don't think the reds are adjustable, just the yellows. I could be wrong though..If it were adjustable, it would have come with a little **** to keep in your car, and you just place it on the top of the strut (the part that sticks through the strut tower, into the engine bay), and twist.
Old Oct 10, 2001 | 05:54 AM
keithv's Avatar
Default Re: Yay!! Suspension parts FINALLY came in!! (martini)
I am 99% sure the Koni Reds a non-adjustable. Hope your question was a joke....
Old Oct 10, 2001 | 07:50 PM
Dru-Si's Avatar
Default Re: Yay!! Suspension parts FINALLY came in!! (breaka_1_9)
Uhhhh.....no, im not joking. The box itself says ADJUST SHOCK ABSORBERS. It's really hard to understand the instruction manual, that's why I posted this. Yes, the yellows have a ****, I know that. I remember someone saying the Reds are adjustable as well.
Old Oct 11, 2001 | 05:06 AM
keithv's Avatar
Your best bet is to check the Koni site http://www.koni.com and see what is says on there.
Actually, I saved you some time. Check this link out... http://217.160.44.27/KONI_NL/_cars/_.../identifi.html
What model Konis do you have? Once you tell me that, I can help you out more...
HTH.
[Modified by breaka_1_9, 9:11 AM 10/11/2001]
Old Oct 11, 2001 | 06:33 AM
TypeR0207's Avatar
Sorry, I got KYB's (and still waiting for them to arrive), can't help ya ......
Old Oct 11, 2001 | 05:26 PM
Dru-Si's Avatar
Thanks for the link breaka. I believe mine are the 8040/8240 series.
One more question: So I got H&R Sport springs with the shocks. The back end is almost 2" lower, but the front is still the same. Would you or anyone else know what the problem is?
Thanks again.
Old Oct 11, 2001 | 06:36 PM
FifthGearOnline's Avatar
springs backwards?!?!?
Old Oct 11, 2001 | 07:05 PM
Dru-Si's Avatar
Default Re: Yay!! Suspension parts FINALLY came in!! (fifthgearonline)
I was afraid of that, but I checked and that's not the case.
Old Oct 12, 2001 | 03:18 PM
Dru-Si's Avatar
Anyone know if the shocks will 'shorten' up a bit if I adjust it so it's firmer?
Old Oct 14, 2001 | 03:41 PM
keithv's Avatar
Do these reds have adjustable spring perches on the shocks? If so, trying moving the front springs down one notch.
Old Oct 14, 2001 | 07:39 PM
Dru-Si's Avatar
I just found out they have adjustable perches. How do I adjust it? Sorry for the dumb questions, but I don't want the guy who installed it to mess up again. I'm getting the front fixed tomorrow afternoon.
Old Oct 15, 2001 | 04:53 AM
keithv's Avatar
There should just be a C clip that snaps into a groove on the shock. You might be able to see the grooves if the dust cover was not put back on...
Old Oct 15, 2001 | 07:14 AM
Dru-Si's Avatar
Thanks. Hopefully things will work out this time.
Old Oct 15, 2001 | 04:03 PM
Dru-Si's Avatar
Is trimming the bumpstop up front a bad thing? I was thinking of getting my installer to trim off an inch or so. Yes/No?
Old Oct 15, 2001 | 05:46 PM
keithv's Avatar
Trimming the bumpstop is a necessity when lowering the car. If you don't trim it, you might bottom the suspension out on the bumpstop.
I trimmed my bumstops in half when I lowered my Teg 1.3" with the Eibach Pro-kit springs. When I lowered my Civic with Ground Controls, I threw away the bumpstop.
monsoon
Suspension & Brakes
10
May 5, 2007 05:48 PM
dkny_stylez
Mar 6, 2005 08:10 AM
mystikteg92
Mar 17, 2004 07:01 PM
hmongboyLS
Sep 4, 2003 03:56 PM
bearboy80
May 22, 2003 06:06 AM
