Anyone have a clutchnet clutch? Or other aftermkt clutches?
I believe many people on this board have Clutchnet clutches from Importparts.com They are a great value, and high quality
They are GREAT! Too bad my car got totalled with about 600miles on it..
I had the stage 1, and it grabbed pretty hard. I would assume it would work for all mild all motor or FI setups (but i would get at least stage2 with a turbo/sc)
The stage 1 has a super light pedal feel, almost TOO light. I would just get the stage 2, just in case you want to go real fast
i have a clutchnet stage 1, it works good. when ever i pop the clutch it grabbed pretty hard. it's like factory but it grabs a lot better.
pedal feel on my stage 1 is like factory pedal feel. before i put stage 1 in i had stage 2 in there and i didn't like it at all. all i had it for was 2 weeks and there was too much chatter in 1st gear. but that’s only my option..
I have the clutchnet stage 2 setup. I got it from ben at importparts.com for 350.00 with the bearings. The pedal feel is really light, but I got used to it after 2 days. To tell you the truth, I think the pedal is stiffer at the top than stock, but lighter than stock towards the carpet. I can be wrong though. When you want to drive normally, it can be driven to feel close to stock engagement but feels much more solid. When you want to dump it, it'll engage real hard. I'm very happy with my clutch, especially with the price I paid for it. The clutch chatters a little, even in neutral sometimes. If you feather the clutch a little to avoid harsh engagement into 1st, 2nd, and sometimes 3rd, you sometimes hear a squeak. I think these are normal occurences from what I've read in other posts. Bottom line, this clutch is very strong and won't tire your left leg out at all.
