how to hook up turbo oil feed and oil pressure all at once
Old Feb 11, 2004 | 09:42 PM
yusoslo's Avatar
Default how to hook up turbo oil feed and oil pressure all at once
block is a d16z6 and I see the factory sender unit right above the oil filter. This engine was never in the car, so was anything ever connected to that?
What is the best way to hook up my oil feed line and my oil pressure gauge to this setup?
Do you remove the stock sender unit?
Pics would be great!
Old Feb 11, 2004 | 10:31 PM
Blackack26's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (yusoslo)
I've heard you throw a code without the stock moron meter in place(could be wrong though,), just buy two tee's and hook up both.
Old Feb 11, 2004 | 11:57 PM
GOLDBERG's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (Blackack26)
yank the sensor and put a tee in...i drove my turboed honda for 2or 3 weeks with the sensor in my house and the oil light never came on................................................ ..................................
Old Feb 12, 2004 | 03:27 AM
fuccarlos's Avatar
get a greddy oil block adapter leave your stock sending unit in place the block adapter goes in between the oil filter and the block
Old Feb 12, 2004 | 04:10 AM
JonGP4's Avatar
anyone try putting the stock sensor in one of the oil journals in the head, on the dizzy saide there are 2 allen screws u can pull out and they are high pressure oil.. i figure the head is going to loose oil pressure first why not put it there, and have the oil feed on the back of the block
Old Feb 12, 2004 | 05:23 AM
xenocron's Avatar
https://honda-tech.com/zerothread?id=377208
Old Feb 12, 2004 | 08:13 AM
Bailhatch's Avatar
Default Re: (fuccarlos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fuccarlos &raquo;</TD></TR><TR><TD CLASS="quote">get a greddy oil block adapter leave your stock sending unit in place the block adapter goes in between the oil filter and the block </TD></TR></TABLE>
This method is the best way. you retain your stock sender. you have 2 1/8" ports and one big one that could be reduced if needed. You won't have any problems with fittings cracking from too much weight in them (like you do with Ts). Much cleaner and cheaper than an ugly distribution block on the firewall, I hate those. it's easier to get to the filter too, at least on a d series. anyway, yes get an adaptor plate. Someone posted one brand that is under 50$ on here recently...
Old Feb 12, 2004 | 08:14 AM
Bailhatch's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=377208</TD></TR></TABLE>
this is the ugly bad expensive way^
Old Feb 12, 2004 | 09:18 AM
yusoslo's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (Bailhatch)
sound like a easy choice for me.
which oil sandwich is cheaper? the greddy or GE
Old Feb 12, 2004 | 09:57 AM
HXMan's Avatar
I wouldn't say it is ugly or expensive. The cost for the fittings is only like $15, and the only other thing you need is the line.
Old Feb 12, 2004 | 10:14 AM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: how to hook up turbo oil feed and oil pressure all at once (HXMan)
or instead of getting the greddy adapter you get the "ghettody" adapter by going to home depot and getting a 1/8 NPT female T from the plumbing section for 65 cents.
most of them are brass but you find some in steel if you make the trec to ACE hardware....
Old Feb 12, 2004 | 10:18 AM
b18b1hmtlove's Avatar
http://shop.vendio.com/funinfeenix/category/4897/
Old Feb 12, 2004 | 10:27 AM
yusoslo's Avatar
Default Re: (b18b1hmtlove)
i thought the whole reason for the greddy adaptor was to relive stress on the components.
Supposedly people have their oil sendors crack?
Whatever the reason I just need to hook up oil feed and oil pressure sensor
Old Feb 12, 2004 | 12:35 PM
xenocron's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">this is the ugly bad expensive way^</TD></TR></TABLE>
And a Greddy adapter is the pretty, good, cheap way?
$45 for everything in that thread and your block is safe...you also can add another sensor without having to jack up the car.
Why add BLING when you cant see it anyway...Greddy Oil adapter...useless IMO.
The cheaper adapter you can find at ANPLUMBING.com But it only has one port and its like 3/8" so you have to buy some extra fittings to size it down to 1/8".
Old Feb 12, 2004 | 01:38 PM
B18EG6's Avatar
haha... not even gonna reply to that one.
just curious......does the greddy kit come with everything you need, lines and all?
Old Feb 12, 2004 | 02:38 PM
Rory Breaker's Avatar
Default Re: (JonGP4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JonGP4 &raquo;</TD></TR><TR><TD CLASS="quote">anyone try putting the stock sensor in one of the oil journals in the head, on the dizzy saide there are 2 allen screws u can pull out and they are high pressure oil.. i figure the head is going to loose oil pressure first why not put it there, and have the oil feed on the back of the block</TD></TR></TABLE>
Does anyone have any more information on this?
My OBD1 throws no codes with no oil pressure sender.
Old Feb 12, 2004 | 03:11 PM
psi420's Avatar
Your car won't throw a code with no sender because its a ground.
Old Feb 12, 2004 | 03:22 PM
CaptainMorgan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">http://shop.vendio.com/funinfeenix/category/4897/
I have the same fitting but instead of having one port on the side it has another one for a boost gauge. so a total of three holes. If you want i can send you a pic.
Old Feb 12, 2004 | 03:43 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (doubler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doubler &raquo;</TD></TR><TR><TD CLASS="quote">
I have the same fitting but instead of having one port on the side it has another one for a boost gauge. so a total of three holes. If you want i can send you a pic.</TD></TR></TABLE>
Huh? Oil pressure boost? This is a fitting for OIL, not air.
Old Feb 12, 2004 | 04:16 PM
Bailhatch's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (B18EG6)
ok, well maybe not expensive (mine was free so..) but it sure does look gay to have lines and fitting and senders all hanging off your firewall. I like having the least amount of aftermarket crap bolted to my motor, or at least visible.
I was just thinking, the $50 adapter and $45 for a feed kit. Not bad considering it fixes all of the problems people have with block Ts and the unnecessary complexity of a firewall mounted T/sender/oil feed junkcluster. Plus the filter adapter plates have the capacity to add oil coolers and other senders easily.
Old Feb 12, 2004 | 04:17 PM
Flamenco-T's Avatar
Run a line from the block to the firewall. Then you can install your oil pressure gauge, stock sender, and turbo feed line from there.
Just like this, but instead of the LS/Vtec line, you can install your oil pressure gauge sender there.
Best of all, the kit with the lines assembly and BSPT adapter is $ 25 shipped.
stan
Old Feb 12, 2004 | 04:21 PM
$25 now?
Old Feb 12, 2004 | 04:24 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18b1hmtlove &raquo;</TD></TR><TR><TD CLASS="quote">$25 now?</TD></TR></TABLE>
yeah...
stan
Old Feb 12, 2004 | 05:30 PM
Bailhatch's Avatar
Default Re: (Flamenco-T)
this is the AN one mentioned above
http://www.anplumbing.com
Item #: 514
Thread: 20mm x 1.5
Port Size: 3/8 npt
Fits: Many Honda and Acura, Some Ford.
Price: 26.36
here is another (looks like a greddy knock off)-http://www.autodynamic.com/detail.asp?PRODUCT_ID=AC-GS-OS10x
might work got it from here-
https://honda-tech.com/zerothread?id=676457
here is the greddy one. 68 bucks.
http://www.greddy.com/products...=1475
for those that doubt, I have done both these setups more than once. filter adapter owns.
Modified by Bailhatch at 9:50 PM 2/12/2004
Old Apr 2, 2004 | 06:27 AM
TurboBumblBee's Avatar
Default Re: how to hook up turbo oil feed and oil pressure all at once (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">Run a line from the block to the firewall. Then you can install your oil pressure gauge, stock sender, and turbo feed line from there.
stan</TD></TR></TABLE>
Stan-
can you give me a quote on the parts needed to hook up the oil feed line to my turbo coming off my stock oil pressure sensor with extra ports so that i can install my stock oil pressure sensor, and a oil pressure guage as well..
thanks
ryan
