Passenger Airbag Removal
Old Feb 11, 2004 | 09:14 PM
jdmspoonitr's Avatar
Default Passenger Airbag Removal
Well....my drivers airbag has been removed and you guys say that disables my passenger airbag too. So I'm trying to take this thing out and put in the blocker. Yes I have searched and found nothing that can help me.
I've taken out the glove, removed the brace holding the airbag to the car, and removed the two 10mm bolts on the side. What else is there? The edge toward the windshield seems to be coming out but it seems pretty stuck now and I don't want to force the thing. Should it be coming out easier? LMK before I break something.
Old Feb 11, 2004 | 09:21 PM
nekkedR's Avatar
Default Re: Passenger Airbag Removal (jdmspoonitr)
just give it a double check up in there, i thought there were like 4 little nuts that held it in from the top, but i also know that it sorta "pops" out. i got mine out and took the cover off the air bag and poped it back in the dash for the "factory" look.
Old Feb 11, 2004 | 09:27 PM
Default Re: Passenger Airbag Removal (nekkedR)
4 nuts where? I know there is one on the passenger side and one on the driver side, but where are the rest? I took off the lower bracket too. hmmmm....
Old Feb 11, 2004 | 09:34 PM
nekkedR's Avatar
man its been awhile, i thought there were like 4 across the bottom, then i remember messing with some 10mm nuts way up in there. you gotta look way up there. if you dont see any more umm i dont know, pull harder
Old Feb 11, 2004 | 09:39 PM
yeah i did the four lower ones to remove the bracket from the dash and the airbag from the bracket. 4 10mm ones. Then there were two 10 mm way up in there on each side. Was it hard to pop it out? Or did you have to force the thing out?
Old Feb 11, 2004 | 09:44 PM
baonest's Avatar
those airbags need to have some force to pop them out..
nekkedR's Avatar
sunds like you got them all, it was pretty hard, i remember thinking i was gonna break something, then i realized it was an air bag and i would be safe. pull harder.
Old Feb 11, 2004 | 09:48 PM
Ahhhhh....finally did it. Yeah I just needed to give it a tug from the top instead of trying to push it from the bottom. Thanks all!
Modified by jdmspoonitr at 11:19 PM 2/11/2004
Old Feb 12, 2004 | 08:48 AM
hypa's Avatar
I thought the same thing last night when I took mine out.
Old Feb 12, 2004 | 09:21 AM
jonas's Avatar
word up, those airbags can be a biotch.
johnclaunch
34
Sep 11, 2008 12:58 PM
FONK
Dec 6, 2005 06:04 PM
citanest
Dec 20, 2001 05:48 AM
