Skunk2 Intake Manifold.....questions.....
Old Feb 11, 2004 | 08:34 PM
Superdragr45's Avatar
Default Skunk2 Intake Manifold.....questions.....
im looking into the Skunk2 manifold for my d-series......and i have got a few quick questions
1) where will i notice the most gains???
2) does i work wit the stock throttle body with no mods??
thats all i mainly have for now.....any help/advice will help.......
Old Feb 11, 2004 | 09:14 PM
TurboBumblBee's Avatar
Default Re: Skunk2 Intake Manifold.....questions..... (Superdragr45)
i have a skunk2 IM on my b18c1 and i noticed a huge difference when i installed the new manifold..
as for the throttle body you should not have any problems at all cause its designed to use the stock tb
Old Feb 11, 2004 | 09:17 PM
MrIllegalX's Avatar
upper RPM band, works with stock TB w/ no mods.
Old Feb 11, 2004 | 09:33 PM
Default Re: (MrIllegalX)
cool guys.......what about installation, was it hard and time consuming, or pretty much a walk in the park?? cuz im curious as to how u get to the underside on the manifold to get to the bolts.....
Old Feb 11, 2004 | 10:31 PM
Archidictus's Avatar
Unceasing Measure
Default Re: (Superdragr45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Superdragr45 &raquo;</TD></TR><TR><TD CLASS="quote">cool guys.......what about installation, was it hard and time consuming, or pretty much a walk in the park?? cuz im curious as to how u get to the underside on the manifold to get to the bolts.....</TD></TR></TABLE>
Take off the hood and cover your fenders with a blanket so you don't scratch the paint. Remove any auxiliary **** in your way and go at it .
Old Feb 11, 2004 | 10:35 PM
MrIllegalX's Avatar
simple, just unbolt anything in the way. make sure you get a new IM gasket and you scape ALL of the old one off, or you'll have vaccum problems.
Old Feb 11, 2004 | 11:48 PM
95civicracer's Avatar
go ahead and grab hondata/nextgear gasket while you got that **** off that is what i did on my d16z6 when i did it.
Old Feb 11, 2004 | 11:56 PM
So Cal So Boosted's Avatar
Default Re: (95civicracer)
also get some stickers so you can mark all the hoses so you put them back in the right spot......ecspecially if you have a bad short term memory like me
Old Feb 12, 2004 | 04:21 AM
xavior66's Avatar
Yeah might as well get that Hondata gasket while you got the intake manifold off. It helps keep the intake charge temps down.
Old Feb 12, 2004 | 04:27 AM
kKdARIAN's Avatar
Vice President/CEO
direct bolt on to your TB.
Do some searching, you can find alot of good info about this manifold and the advantages of the edelbrock manifold.
Old Feb 12, 2004 | 05:09 AM
SOHC_MShue's Avatar
I would recommend the edelbrock manifold over the skunk2 for the D series. I installed the skunk2 on my buddy's car and didn't feel much if any power gain over the y8 manifold. However I am sure you can make more power with tuning such as using an adjustable fpr to raise the fuel pressure. Also those bolts under the manifold are not hard to get through. You should be able to get to the middle bolt on the bottom from the engine bay, but for the bottom bolts on that bracket that holds it up you will have to jack it up and go underneath...I did anyways. Good Luck!
civicsaremean
Oct 18, 2007 07:22 PM
McFlurry
Jul 6, 2006 05:31 PM
Quitripin
Jun 9, 2004 12:46 PM
JDMvtecDRAGSTA
Mar 29, 2004 09:00 AM
JM Performance
Jul 23, 2002 05:24 PM
