99 civic hx question
Old Feb 11, 2004 | 08:27 PM
speedzone7226's Avatar
Default 99 civic hx question
yea i was wondering how i could rig my car to start without pushing in my clutch i've seen it done before but im just wondering how to do that. and what i need and how to install a kill switch to my car........thanks
Old Feb 11, 2004 | 08:30 PM
HXMan's Avatar
Default Re: 99 civic hx question (speedzone7226)
You will have to remove the clutch switch...very simple actually.
Old Feb 11, 2004 | 08:31 PM
b16si's Avatar
Default Re: 99 civic hx question (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan &raquo;</TD></TR><TR><TD CLASS="quote">You will have to remove the clutch switch...very simple actually.</TD></TR></TABLE>
do you have pics or a write up on a how to?
Old Feb 11, 2004 | 08:36 PM
HXMan's Avatar
Default Re: 99 civic hx question (b16si)
Just look under the dash and follow up the clutch lever.
When you push it down you will notice a small plunger style switch.
All you need to do is unscrew the switch. The switch will then stay in the open position making the car think you have the clutch pushed in.
Old Feb 11, 2004 | 08:55 PM
but when im driving how will it knoe if the clutch is or is not down
Old Feb 12, 2004 | 02:34 AM
CYankeeboy's Avatar
That switch is only for the start function or if you have cruise for that as well. If you use the cruise, I wouldn't disconnect this switch. The first time you push in the clutch with the cruise set, bad things will happen It will redline faster than you can react. As far as normal clutch operation, it won't make any difference.
Craig
Old Feb 12, 2004 | 07:22 PM
Default Re: 99 civic hx question (CYankeeboy)
where uder the dash??? could you please be more discriptive? so everything will work the same after i do it? in the long run could it do any damage to my car in any way besides the cruise????
allen
Old Feb 12, 2004 | 07:25 PM
4everlost's Avatar
just follow the cluth pedal. this is an easy task
Old Feb 12, 2004 | 08:23 PM
Default Re: 99 civic hx question (blackcap)
could a 96 civic hood fit on my ride&lt;99 honda civic hx&gt;
Murf72
15
Sep 17, 2016 01:32 PM
deeboi
Aug 24, 2015 09:47 PM
zc89hatch
Feb 2, 2008 09:05 AM
GDM93Si
13
Dec 12, 2004 10:53 AM
