relay clicks but nothing happens. not even turn over at times
Old Feb 11, 2004 | 07:58 PM
wambus's Avatar
Default relay clicks but nothing happens. not even turn over at times
I had made a post asking how likely it is for a main relay to go bad.When i went to start my car, the relay would click loud and in a random pattern suond. The car would turn over slowly then fire up. Now I turn the key, the relay clicks, the fuel pump IS priming, but the starter does not engage. Its a new starter and works fine.New optima battery as well. so whats causing the starter to not work and now dot even try to work. Just click under the dash and nothing. I have to push start my car now. but once it started right up again... whats the deal?
Old Feb 11, 2004 | 08:02 PM
EL SARGENTE's Avatar
Default Re: relay clicks but nothing happens. not even turn over at times (wambus)
Check ur starter solenoid...could have been bad to start with...who knows...any other ideas??
Old Feb 12, 2004 | 03:09 PM
nub's Avatar
nub
when you say the relay clicks do you mean the main (pgmfi) relay or the starter solenoid. could be the ignition switch or bad battery conection at the battery itself,starter or chassis ground.
jdmunlimited1
Apr 3, 2010 05:47 PM
keviiinnnnn
Jan 2, 2008 07:27 PM
Junkyard2000
Nov 17, 2005 12:03 PM
eth0r
Jul 8, 2005 05:19 PM
Sexy_Chantal
Oct 28, 2004 04:18 PM
