Hondata tuners please help: loss of power/hesitation @ vtec engagement
Old Feb 11, 2004 | 07:56 PM
boostismycrack's Avatar
E-thug
Default Hondata tuners please help: loss of power/hesitation @ vtec engagement
I have recently installed my s100w/ boost. my vtec is set to 5000rpms (type r cams) When vtec comes on under boost, I experience a drastic loss of power along with hesitation although air fuels stay between 11.5 and 12.5. It seems worst in first gear. Anyone have this problem?
Old Feb 11, 2004 | 08:17 PM
int3gra's Avatar
Default Re: Hondata tuners please help: loss of power/hesitation @ vtec engagement (boostismycrack)
search "hesitation" in this forum, tons of threads on it.
and yes ppl have been having problems.
also check the hondata message board. there are some solutions.
http://www.hondata.com
just read a new thread on where hondata solved it for one guy and it was due to problems not related to hondata, faulty wiring, temp sensors, etc..
Kataku2K3's Avatar
It really depends on your motor setup, how much boost you're running, etc. but on an FI motor sometimes having the VTEC too high will make it take a dump in power... If you're set too high and you drop it down most of the time it'll broaden your powerband slightly... Typically we set it to x-over anywhere from 4000-4800rpm depending on the setup... Just my $0.02, Good Luck
Old Feb 11, 2004 | 08:36 PM
E-thug
Default Re: Hondata tuners please help: loss of power/hesitation @ vtec engagement (Kataku2K3)
I'm running a b18c1 10:1 je pistons, eagle rods, b16 head w/ rev valvetrain, type r cams, jg intake manifold, gt35e turbo, hondata s100b @ 8psi.
Old Feb 11, 2004 | 08:41 PM
psi420's Avatar
It's your Hondata.
BTW - Get rid of the R cams on your boosted application.
https://honda-tech.com/zerothread?id=550794
https://honda-tech.com/zerothread?id=207823
Old Feb 11, 2004 | 09:08 PM
E-thug
Default Re: (psi420)
what about the hondata? not everyone runniing hondata has this problem. the gsr/typer cam debate will never end.
Old Feb 11, 2004 | 09:12 PM
psi420's Avatar
Default Re: (boostismycrack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostismycrack &raquo;</TD></TR><TR><TD CLASS="quote">what about the hondata? not everyone runniing hondata has this problem. the gsr/typer cam debate will never end.</TD></TR></TABLE>
What the hell do you mean the debate will never end.
Talk to any reputable tuner and see what they prefer.
ITR's have more overlap for N/A applications.....why the hell do you want that on your turbo motor?
Maybe the debate will never end where your at, but I thinks its been pretty much settled here for years.
Second, the Hondata issue.....read the ******* links I posted.
2b & 3b users dont have the problems that the S100 and S200 users are having.
Old Feb 11, 2004 | 09:20 PM
E-thug
type r have made over 500whp in boosted applications, so whatever dude. Too much coffee for you, sorry I missed your links, I'll go read them now.
Old Feb 11, 2004 | 09:33 PM
Mase's Avatar
ya know its funny, we made 540whp on ITR cams, and im pretty sure Boostfed made 600 on his as well. just to name a few.
feel free to take your foot out of your mouth at any time
Old Feb 11, 2004 | 09:46 PM
Kataku2K3's Avatar
Default Re: (Mase)
We've always run GSR's but I've definately seen good stuff from ITR cams... Nick runs them in his Teg and that thing runs awesome...
Old Feb 12, 2004 | 03:05 AM
ekb18c's Avatar
Default Re: (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">ya know its funny, we made 540whp on ITR cams, and im pretty sure Boostfed made 600 on his as well. just to name a few.
feel free to take your foot out of your mouth at any time </TD></TR></TABLE>
ITR's are great with boost. I made 535whp on them @ 21psi.
Old Feb 12, 2004 | 03:10 AM
ekb18c's Avatar
Default Re: (Mase)
btw- how does you timing map look like? Your are right in the the center of the cross over from low speed and high speed.
Take a closer look at your timing map. Most timing maps should be linear with a upward movement.
Old Feb 12, 2004 | 03:54 AM
Chillinit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">
2b & 3b users dont have the problems that the S100 and S200 users are having.</TD></TR></TABLE>
hell ****...**** hell...calm the **** down
and like mase said...let us know when ur gonna take ur foot out of ur mouth...
Old Feb 12, 2004 | 04:53 AM
ladysman's Avatar
Default Re: (Mase)
Own3d.
To the thread starter, datalogs help a ton for diagnosis. Got any? There are a few of us here that can look at them.
Old Feb 12, 2004 | 09:31 AM
psi420's Avatar
Default Re: (Mase)
As soon as I get my **** out of your mom.
Old Feb 12, 2004 | 09:36 AM
ekb18c's Avatar
That was very mature of you...
b18b1hmtlove's Avatar
change your vtec engagement maybe? I believe the generally selections are 4200 on a D series and 4800 on a B series. Try it out, it might work for ya. Otherwise it could be vaccum map problems.
Old Feb 12, 2004 | 09:52 AM
E-thug
Default Re: (ekb18c)
Thanks I'll look into that.
Old Feb 12, 2004 | 09:54 AM
E-thug
Default Re: (ladysman)
Thanks ladysman, my fjo is comming in today, my previous wideband is 5 yrs old, no datalog capabilities. I will try to get it up and running later but its been raining for days here, so hard to tune.
Old Feb 12, 2004 | 11:07 AM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by psi420 &raquo;</TD></TR><TR><TD CLASS="quote">It's your Hondata.
there have been serveral posts showing 20hp gains with ITR cams over GSR cams...search em' up!
mike
Old Feb 12, 2004 | 12:18 PM
psi420's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb18c &raquo;</TD></TR><TR><TD CLASS="quote">That was very mature of you... </TD></TR></TABLE>
You know what.....no one asked you.
Keep your ******* comments to yourself.
Old Feb 12, 2004 | 12:19 PM
psi420's Avatar
Default Re: (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
Better yet, why dont you show me.
I am interested in seeing dyno charts with strictly cam comparison on a boosted motor.
Old Feb 12, 2004 | 12:31 PM
MikeMAN's Avatar
goddamn't wrong link
Old Feb 12, 2004 | 12:34 PM
MikeMAN's Avatar
autoEXturbo
Offline
1882 posts [100%]
FRANK THE TANK
5-28-2002
Re: gsr or itr cams......better? (gsrcivict) 4:02 PM 1/7/2003 Reply Edit
i believe we made about 20-30 more hp with the type r cams on my gsr motor. All i have is my current dyno sheet though, so i can't show the difference.
[Modified by autoEXturbo, 5:05 PM 1/7/2003]
Old Feb 12, 2004 | 12:35 PM
psi420's Avatar
https://honda-tech.com/zerothread?id=704660
there ya go smartass
Of course he's gonna make more over the Si cams.
Thats a given, put the test to the GSR vs the ITR
Or, do you have another link for my smartass?
