Got a couple of questions
Ok guys heres the story. I decided to build a D for turbo for 3 reasons.
A) Tired of everyone saying D's are pointless, and I need to swap a B series in
B) At the time I already had a D series turbo kit (just sold the mani and turbo to fund the build up)
c) For what I would pay for a low model B series I can have a fully built D series
Well I traded my std mani and TDO5 turbo for a Y8 port and polished head, oversized valves, new dual valve springs, and new valve retainers. Today my Eagle H beam rods came. So now all I need is pistons. Now here are the questions.
1) I did a conversion calculator I found on h-tech and it said a D16A6 witha Y8 head using A6 pistons raised the C/r to like 10:1. So if I use 8.5:1 compression pistons what will that put me at? Should I just use Y8 pistons?
2) I have a guy with a D16Y7 block for sale. With no crank, wanting $50 shipped. Is this a decent deal?
3) Do I really need to resleeve the block for turbo? What are the factory sleeves good for? I will be running no more than 15 psi when at the track. Where is a good place to get them? I found them by LA sleeves for $20 a piece. I don't know if they are stock replacement or not, for $20 a piece I think they are.
4) Anyone have a A6 block for sale or they want to get rid of? Kinda short on cash right now. Any help would be appreciated.
5) Will any D series intake mani fit the Y8 head or does it have to be a Y8?
6) Are all adjustable cam gears the same or should the e-bay ones work just fine?
Thanks, Doug
Thanks, Doug
Oh yeah where is the best place for a gasket rebuild kit? Tge only one I found was for a Y8 or Y7
Make/Model: Honda Civic Del Sol 16V SOHC
Year: 96-00
Engine Code: D16Y7
Stock Bore: 75mm
Kit #: EKH30MPX
Price: $979
Engine Kit Includes:
Complete Gasket Set
Cometic Head Gasket
SRP Forged Pistons
#149205 2.953 (75mm) bore, 10.5-1 comp ratio
#149206 2.963 (75.5mm) bore, 10.5-1 comp ratio
#149207 2.972 (75.75mm) bore, 10.5-1 comp ratio
#149208 2.953 (75mm) bore, 9.1-1 comp ratio
#149209 2.963 (75.5mm) bore, 9.1-1 comp ratio
#149210 2.972 (75.75mm) bore, 9.1-1 comp ratio
ROSS #00661 (75, 76, 76.5, 78mm bore) and (8.5-1, 9.5-1, 10-1, 11-1, 11.5-1 comp ratio)
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
Year: 96-00
Engine Code: D16Y7
Stock Bore: 75mm
Kit #: EKH30MPX
Price: $979
Complete Gasket Set
Cometic Head Gasket
SRP Forged Pistons
Performance Rings
Thrust Washers
Timing Belt
Expansion Plugs
From: the asshole of america..., upstate new york, USA
1) d16a6 block/pistons, d16y8 HG, y8 head = 10.33:1
same as above but with y8 pistons = 9.6:1
same as above but with z6 pistons = 9.45:1
8.5:1 compression y8 pistons will give you 8.5:1 in a d16a6 block as long as you use the y8 head.
2) depends on if you can find a whole engine at the junkyard for $70.
3) not too sure on this one. i remember reading a post on http://www.theoldone.com/forum that talked about if going over 75.5mm that sleeving is required...but i cant remember if that was for n/a or for boost applications. i looked and cant find it now.
4) no
5) any d series 88+ except the d16a1...as far as i have read. your best bet would probably be a y8 or z6 manifold.
6) no idea... i spent the extra money for the jg/edelbrock one just for peace of mind.
4) no
turnsignalandy
Aug 17, 2006 11:12 AM
Almost There
Apr 30, 2006 04:22 PM
