are all crx's the same size inside??
Old Feb 11, 2004 | 06:53 PM
stevecrx04's Avatar
Default are all crx's the same size inside??
ok, my question is are all crx's the same size inside, like threw the 88-91 models?? cause i saw some 88's and the back looks way smaller then other crx?? if anybody can help that would be great
Old Feb 11, 2004 | 07:10 PM
Wiz's Avatar
Wiz
Default Re: are all crx's the same size inside?? (stevecrx04)
Well statistics taken from 89crx.com indicate There is a difference in shoulder room between 88 and 91 models but I believe its a misprint.
Methinks they are all the same size as far as room within the cabin.
The reason the back may look smaller, maybe from an outside perspective could be that the lights are slightly different, if I'm not mistaken the tail lights are fatter on the 90/91 and thinner on the 88-89
someone confirm this
** after further investigation the length is actually shorter in the 88
88 width = 65.7
88 length = 147.8
90 width = 65.9
90 length = 148.5
Modified by Wiz at 11:29 PM 2/11/2004
Old Feb 11, 2004 | 11:58 PM
Nerologic's Avatar
from my knowadge, and i have had 8 CRX's and i measured a few for my own knowlegd they were exacly same size, and HONDA used the same chassis, so i go with yes same size
Old Feb 12, 2004 | 12:10 AM
bryant's Avatar
Inside no. Si's are 3" less headroom I think it is, due to the sun roof.
nokehockey20
Jun 6, 2016 10:08 AM
dmotoguy
Welding / Fabrication
Jan 22, 2007 09:45 AM
AWD: Jeff
Jan 18, 2007 01:33 PM
1990hondaHF
May 17, 2006 10:29 AM
