Tire life expectancy
Old Feb 11, 2004 | 06:40 PM
py1188's Avatar
Default Tire life expectancy
Maybe this is in the wrong forum, but since I post here most I figured this would be the right place.
I was just curious as to whether or not there were any negative side effects of using an older set of r compound tires that hasn't been run on in a while....~3 years or so??
TIA
Old Feb 11, 2004 | 06:46 PM
mikestypeR
Guest
Posts: n/a
Default Re: Tire life expectancy (py1188)
probly not ... i am no expert but i dont think tires go bad?
however if they were exposed to the elements and are heat cracked or dry rotting then i would assume not to use them.... if they look fine then hell yeah buRn them
Old Feb 11, 2004 | 06:52 PM
nsxtasy's Avatar
H-T Order of Merit
You coming to the track with us this year, Erick?
Old Feb 11, 2004 | 10:20 PM
py1188's Avatar
Default Re: Tire life expectancy (nsxtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy &raquo;</TD></TR><TR><TD CLASS="quote">You coming to the track with us this year, Erick?
Yeah I went o a few CGI events last year, but unfortunately you weren't at any of them. I did meet a ton of helpful people, however, all of whom knew you
I hope to see you guys a lot this year
Old Feb 11, 2004 | 11:20 PM
92TypeR's Avatar
FSAE
This Porsche guy I was talking to at the track last year was running on 14 year old hooseirs Seemed to hold up fine as he was very fast.
Old Feb 11, 2004 | 11:28 PM
cheezthis's Avatar
Should be fine if they're not dried up and cracked.
You should come out w/us to MAM whenever that happens again...as well the Gingerman events. I'd like to finally drive Grattan this year too. Always heard great things about it, and then Ken's vouch for it recently made it even more a "must" for this year.
Old Feb 12, 2004 | 03:15 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by py1188 &raquo;</TD></TR><TR><TD CLASS="quote">I was just curious as to whether or not there were any negative side effects of using an older set of r compound tires that hasn't been run on in a while....~3 years or so??</TD></TR></TABLE>
Depends on how they were stored. If they were stored in a barn, outside, next to a window i wouldnt use them.
If they were stored inside, with some sort of climate control, and in heavy-duty dark trash bags then they will probably be fine.
UV and temperature cycles can be hard on the rubber as its sitting and can make it very hard compared to what it was.
LudemanDan
22
Jun 26, 2006 05:23 PM
THMotorsports
15
Dec 14, 2005 03:01 PM
hYbRid_Eg6
Jun 14, 2005 09:01 PM
Andrew 825SM
15
Oct 12, 2004 03:10 PM
sicivic
53
Dec 11, 2003 12:54 AM
