SOHC TURBO vs DOHC debate at work, please all SOHC turbo guys..HELP
Ok so i have this friend at work who insists he knows more about hondas & acuras then i do. I say BS right off and ask him an easy Q. What does vtec stand for, His very words were "I dont know". Then it turned into him knowing how to make my hatch fast and so on. The main point is he says it is not possible to make a SOHC turbo hatchback (96-99) run 13s all day with a FULLY stock internal motor. He believes doing a motor swap will be the only way to hit 13s. Please just post your mods, timeslips, whatever............so i can show him that STOCK TURBO SOHC motors can easily do 13s.
sure, its possible to run 13's with a D series SOHC motor, but i dont think its worth it. But i'm not sure about keeping the bottom end stock, the rods on those motors suck. The best way is to go with a b16 DOHC. They are cheap, and you can keep the stock block and run 12's.
11's have been done on stock internal D's. 13's are easy. Examples on THIS board: Mista Bone, Singlecam Screamer, BoostedED9, and many others. BoostedED9 made 302whp on a stock block and hit high 11's with boost. Mista Bone 13.02 on a 75 shot, Singlecam Screamer 12.8 with a 60 shot. All stock internals. Tell your friend he is full of ****.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beautifulblue »</TD></TR><TR><TD CLASS="quote">The best way is to go with a b16 DOHC. They are cheap, and you can keep the stock block and run 12's.
Not stock and no boost they won't in a street car.
</TD></TR></TABLE>Not stock and no boost they won't in a street car.
D's are good if you're looking for low horsepower (around 200-300) for the price. Also, it's a cheaper engine so if it blows up.....you can get one for 400-500 compared to 2000-3000 for a new B block. D's are also a little lighter than the B's which gives it a small advantage in my mind
too. To the original questions. Ill (hopefully) be making high 13 passes (13.9) in my my stripped sol this summer. Ill be posting numbers in the spring/summer. That's on street tires.
ive seen people run high 13's with greddy kits on internally stock d16's. its defiately possible.
<-- SOHC powah ninja right here. Stock block, 11psi out of a t3, and 15k miles. It's my 'lil monster. As far as track times go... I'll tell you when the snow goes away!
Matt
Matt
i did 13s stock internals! here was my setup:
d16z6
t25 bastard turbo
starion fmic
dsm injectors
vafc hack
2 1/4" exhaust
ran 13.9@100mph on 16" kumho street tires
d16z6
t25 bastard turbo
starion fmic
dsm injectors
vafc hack
2 1/4" exhaust
I have a JDM D15Bvtec turbo and it is running high to mid 13's running TDO5H @10psi, it ***** and gets my friend stock long block!
i ran a 13.8 on 9psi of boost with a completely stock z6 in a 94 coupe. ~piston rings went in the 4th cylinder though like a month after. 13's are pretty easy for a sohc w/boost 12's are going to be harder esp in a coupe.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racinskittle »</TD></TR><TR><TD CLASS="quote">D's are good if you're looking for low horsepower </TD></TR></TABLE>
This is the point alot of people are missing.
hahaha oh man... more and more i love my sohc. anyway u don't need a dohc for 13's. end of discussion. i hope he's not one of those... b16 lovers. imo if ur gonna go dohc at least get the better B...18C
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITSTOCK »</TD></TR><TR><TD CLASS="quote">i did 13s stock internals! here was my setup:
d16z6
t25 bastard turbo
starion fmic
dsm injectors
vafc hack
2 1/4" exhaust
ran 13.9@100mph on 16" kumho street tires</TD></TR></TABLE>
How much boost? You're setup is very similar to what mine will be.
d16z6
t25 bastard turbo
starion fmic
dsm injectors
vafc hack
2 1/4" exhaust
Guest
Posts: n/a
o man...
another war...what did u start?!
ima sohc with a drag kit. tuned for hondata at only 5lbs, but ima be going to Secret Service in Tampa soon...like next week! hehe, yay...more boost! anyways back to discussion...im only hoping for like more or less 250 at like 10lbs daily. with that much power it is with no doubt i will be hitting 14s...so image in hatch.
oh yeah, ill be rolling in a 00 coupe with a full interior and system. if i dont hit that 14 second run...then u will hear my rollin down the strip
it's possible with either a B or a D. Just gotta make sure it's tuned to keep the power consistent. Your friend's a tool. I was doing 13's on a stock block and now I'm doing 13's on a built block with a DOHC ZC which counts as a D.
I fall into that not quite sure what it is engine because, it has been repeatedly mistaken for a b18. It's a D, the power shows similar to a D. I like D series engines. If I kill this one, it's SOHC vtec, and I'm gonna boost the **** out of it.
i beleive its possible to do that, im not sure on the reliability factor. But its definitly possible. Anything is possible if done correctly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Disco Stu »</TD></TR><TR><TD CLASS="quote">
8 psi
</TD></TR></TABLE>8 psi
