New Best 1/4 Mile
I have:
JDM 4-1 (Definitly the best mod so far)
2.5 Custom exhaust
Testpipe
Icebox
Slicks with Kosei K-1 wheels
Timing 18 Degrees
R/T....754
60' ...2.05
330...5.76
1/8...8.87
mph..79.12
1000..11.52
1/4...13.77 @ 100.10 mph
2.5 Custom exhaust
Testpipe
Icebox
Timing 18 Degrees
R/T....754
60' ...2.05
330...5.76
1/8...8.87
mph..79.12
1000..11.52
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Nice 1/4 mile time...but the 60 foot is horrible for using slicks.
You should easily run a 1.90 60 FT and then you'd probably be in the 13.5-13.6 range.
Hmm...I dont think it does have to do with the small sidewall of the slick..because I used a 20x14x6 sicks..which has a smaller sidewall then the 22x15x8.
I pulled a 1.90 60 ft and a friend of mine using teh same slicks pulled a 1.87 in his SI.
60ft time and slicks...bad launch at 6000rpm, came back to around 4700rpm...1.99 60 ft time, 23X7.5X15 M&H still looked new, unfortunately I only had one run so I have no way of knowing if I could have improved the launch.
Austin
Austin
Austin: That does seem like a bad launch..Im guessing the slicks wernt nearly warmed up enough or the pressure was too high. The RPMs shouldnt drop back down when launching with slicks.
My best 60 ft was dropping the clutch at 4900 and it caught and just climbed from there on up.
Thanks, I have full interior and spare. The only thing I do that is related to weight reduction is make sure I only have about an 1/8 tank of gas. As for launching I don't think I can do much better with the stock clutch.
Nextelbuddy
Jun 19, 2004 09:32 PM
