Difference in 88-89 and 90-91 caliper mounting places?
is there any difference. i got some pads that will only work with the 90 to 91 calipers and was wondering if i could just switch the 88 to 89 calipers to the 90 to 91 or will there have to be modification. my only other option is just taking them back. i don't even know if the calipers i have now work so im trying to work with what i got and just get some new ones.
but as long as i upgrade the rotors and the calipers and the brake pads everythign should bolt up right? thanks for the reply man. big help.
i called honda and they said he could only give me parts number. and i know they are different numbers so question is still up.
89' are stamped 2042 or 2049 and 90' are stamped 16cl13vn. So yeah the calipers are different BUT the knuckles are the same part on a 89' and a 90' crx si. Although the calipers are different it seems like they should bolt to the knuckles the same.
not to jack the post or anything, but i have a 91 DX hatch, and my passenger side front caliper went bad, so i replaced it with a 91 CRX Si caliper which i pulled from the 91 CRX myself.. I was thikning they would be the same....the CRX caliper bolts on and works, but it is different in appearance. Any thoughts on this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">not to jack the post or anything, but i have a 91 DX hatch, and my passenger side front caliper went bad, so i replaced it with a 91 CRX Si caliper which i pulled from the 91 CRX myself.. I was thikning they would be the same....the CRX caliper bolts on and works, but it is different in appearance. Any thoughts on this?
yeah i believe the 90-91 crx si calipers were made by nissin and the 88-89 were made by another company. The nissin calipers are usually found on top models.
kast.aluminum
Jul 30, 2015 03:57 PM
JDM_EK_JOE
Mar 1, 2006 08:16 PM
Zeppelin
Jun 7, 2004 07:49 PM
dustin
Jul 24, 2002 12:49 PM
