wiring harness for 90 hb b16 swap
Old Feb 10, 2004 | 06:18 PM
infantry's Avatar
Default wiring harness for 90 hb b16 swap
i need some fawkin help. i just bought my 90 hatch and it has a d16 motor in it. i was wondering if that is obd0 or if it is even has obd. if it does, can i use that wiring harness for a obd0 vtech motor. and if i cannot, where can i get a harness to change the jap motor to lefthand drive. please help.
Old Feb 10, 2004 | 06:47 PM
1point5CRX's Avatar
Default Re: wiring harness for 90 hb b16 swap (hatching)
its obd-0
Old Feb 10, 2004 | 07:13 PM
virginia_dude's Avatar
Whatever your modle is you need to mod your harness. The JDM B16 harness would need to be rewired , TPS for example on US car goes to drivers side connector, but on SiR harness it goes to the right side. But both cars Injectors go on the left side. I gave up at that point and decided I had to fix my old harness. And strip the KNock sensor and Vtec related stuff from the SiR harness. To make a piggyback harness. Everyone tells you to just do it that way, but not why. Well somethings that need to go on the left go on the right, and somethings that need to go on the right go to the left, and somethings are exactly where they need to be otherwise. Connectors match, but color codes do not, nor do physical pinouts. This is Why a JDM SiR harness inan EF9 will not work on a US spec car. Let me be the first to explain the reason. I looked over both wiring diagrams and even checked physical routing. Hope this turns up on future searchs to save others time.
Its not only easier to mod yours , Because A SiR would be good only as a core to create a new harness from scratch
Old Feb 10, 2004 | 09:54 PM
kanzenr91si's Avatar
Default Re: wiring harness for 90 hb b16 swap (virginia_dude)
its pre obd, and all you need to do is add 4 wires or just get the sub harness from hasport or place racing. good luck
1BADEF
Sep 12, 2008 01:49 AM
ikaika3269
10
Feb 26, 2008 06:25 PM
Beau Gotti
Feb 12, 2006 02:11 PM
