uberdata p28 problems....not sure any ideas HELP PLEASE....
Old Feb 10, 2004 | 05:48 PM
gdrum's Avatar
Default uberdata p28 problems....not sure any ideas HELP PLEASE....
Okay where to start...
I have a p05 that is converted to a p28.
Running uberdata...tested ecu on b16 coupe for many runs ecu is perfect.
Load a h22 basemap and scale to 450's for the turbo kit......put it in the h22 car..and the car will not start, and it throws a code before it starts right away it throws a 21 vtec silanoid code. The car has a broken tps.......but that never usually made it not start, and I cant figure out why it would be that. It has a vafc in it......
I put stock p13 in it and no code 21
What would make this do this...and why...do vafc and uberdata not like each other....ecu is legit cuz it works fine on the b16 with NO cel's......so I am so lost.
And on top of all of that would a car not start just because of a 21 cel? Help please.
Also on tial wastegate's the o-ring....the smaller metal lip should face in or out on the wastegate?
Modified by gdrum at 4:19 PM 2/11/2004
Old Feb 10, 2004 | 05:54 PM
dennis's Avatar
Default Re: uberdata p28 problems....not sure any ideas HELP PLEASE.... (gdrum)
I unfortunately can't help you out with the symptom, but I have to do the same thing to a P05 - how'd the conversion go? You just converted to heated 02 right? I'll be doing the same thing with my F22. Good luck.
Old Feb 10, 2004 | 05:59 PM
hoggy's Avatar
Default Re: uberdata p28 problems....not sure any ideas HELP PLEASE.... (dennis)
Actually I was the one that did the conversion and it was pretty easy. Added all the vtec stuff as well as the transistor for heated o2 and no codes on my car. Grants is a different story. I haven't had a chance to get my hands dirty in it yet. So I'm helping him trouble shoot the ECU over the phone.
Old Feb 10, 2004 | 06:44 PM
gdrum's Avatar
Default Re: uberdata p28 problems....not sure any ideas HELP PLEASE.... (hoggy)
bump
Old Feb 10, 2004 | 06:46 PM
dennis's Avatar
Luckily I don't have to deal with vtec so I think all I have to do is wire in the transistor for heated 02. I know who to bug now when I have problems j/k
Anyway, I'd try another burn to make sure that's not the culprit - could I take a look at your bin file?
Old Feb 10, 2004 | 07:07 PM
b18b1hmtlove's Avatar
pssstttttt try posting on the uberdata forum for help.
Old Feb 10, 2004 | 09:33 PM
gdrum's Avatar
Default Re: (b18b1hmtlove)
bump
Old Feb 10, 2004 | 09:49 PM
ndogg's Avatar
Default Re: (gdrum)
what h22 basemap are you running? get over to:
http://www.ecimulti.org/uberdata/forum
Old Feb 11, 2004 | 07:06 AM
gdrum's Avatar
Default Re: (ndogg)
i got the h22 basemaps from that website...just figured maybe someone on here would know how to help me out....
Old Feb 11, 2004 | 07:47 AM
hoggy's Avatar
already posted on the uberdata forum...just thought i might get some info about the code 21 here though too
jake00si
Feb 8, 2011 07:26 PM
CRX 2.0V-T
Jun 14, 2006 11:23 AM
AgentJam
Feb 7, 2004 08:04 AM
Darksoul
Dec 12, 2003 11:44 AM
