b16 and CA emissions
Old Feb 9, 2004 | 09:23 PM
sauchi55's Avatar
Default b16 and CA emissions
I tryed searching on this but didn't turn up much. I just moved to Cali and I need to know if it is illegal to swap a b16a into my 91 crx si. and even if it is how can I get it past smog and the dmv. any info would help.
Old Feb 9, 2004 | 11:45 PM
B2FiNiTY's Avatar
Default Re: b16 and CA emissions (sauchi55)
yep, it is indeed illegal until you take it to the ref and get your BAR sticker.
Old Feb 10, 2004 | 07:22 AM
temp's Avatar
Default Re: b16 and CA emissions (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">yep, it is indeed illegal until you take it to the ref and get your BAR sticker. </TD></TR></TABLE>
correct, and to elaborate on this further, to make the B16a legal in your car you will need to do an OBD-1 conversion, run a P30 ECU and get the Del sol intake/exhaust manifold and all other emissions related equipment
Old Feb 10, 2004 | 07:55 AM
sauchi55's Avatar
does anyone have a complete list of all the emission equipment
Old Feb 10, 2004 | 07:59 AM
temp's Avatar
catalytic convertor (you have to have one, not necessairly a del sol one)
intake manifold (is necessary due to different vacume line locations)
exhaust manifold (1 02 sensor)
ECU
OBD-1 conversion
those are really the only things you will "need" just remember, any aftermarket parts you put on the car (that affect emissions, IE anything with a CARB number) (if they are on it when you go to the REF) need to be made for the DEL SOL VTEC and nothing else
1_SIK_EG2
Mar 11, 2010 02:10 PM
07jdmfit
May 11, 2009 06:16 PM
andrewp1
Aug 31, 2005 07:35 AM
revin=smiles
Jun 2, 2005 10:14 PM
Mentat Ghola
14
Feb 7, 2004 12:15 PM
