89 carb hell
Old Feb 9, 2004 | 08:13 PM
Krawler's Avatar
Default 89 carb hell
so tis been acting strange latly....revin high for to long then finally droppin a little low...fine i could handle that but now if i get in it warms up fine then as soon as i kick it down it will drop to about 200 and then drop out and die......wtf.....help, oh bye the way it is the eletronic carb with like 38 little 1\4 inch tubes runnin into the black box...it looks like the Borg carb
Old Feb 10, 2004 | 12:27 AM
philadd's Avatar
Default Re: 89 carb hell (Krawler)
those tubes running to the black box are vacuum lines... check to make sure none of them are leaking. carb might also need to be cleaned out...
there's always the possibilty that the carb will need to be rebuilt. if you're mechanically inclined it won't cost too much, but if you have to take it to a shop expect to lighten your wallet by a few hundred bucks.
you may also want to try this forum: http://www.3geez.com
it's a forum devoted strictly to the 3rd generation accord.
Htouring2016
May 5, 2016 01:01 AM
civicmanyep
Jan 29, 2012 05:33 PM
totsie7944
Nov 15, 2006 09:59 AM
Krawler
Feb 15, 2004 12:44 PM
civicqm
Apr 27, 2003 05:33 PM
