Oil change (bolt sealing)
Old Feb 9, 2004 | 07:19 PM
WhitEdRift's Avatar
Default Oil change (bolt sealing)
Alright I've done plenty of oil changes, but for some reason on my 91 Integra there is always a leak from the bolt. Used to have a severe one, then I redid it with some teflon tape around the bolt and high-temp gasket maker. This time I just replaced the washer with a new one that has a rubber seal but it leaks. Is there any material I can apply every time to insure there will be no leak? Some kind of liquid gasket or something that is just a standard in shops?
Any help is appreciated.
Old Feb 9, 2004 | 07:25 PM
swanny's Avatar
Default Re: Oil change (WhitEdRift)
permatex it.
Old Feb 9, 2004 | 07:41 PM
[ iLL ] iNt3GrA's Avatar
get a new plug & gasket for the plug n just tighten it but dont go crazy n over do it maybe u have the wrong size plug
Old Feb 9, 2004 | 07:43 PM
florduhdude's Avatar
Have you tried the plastic washers that they sell in the help section, or maybe an oversized replacement drain plug, or even a new oem drain plug? Have you looked at the drain plug area to see why it's not sealing? With the 9 cars i've owned in my life i've never had one leak from the drain plug, usually they leak everywhere else but.
Old Feb 13, 2004 | 10:44 PM
WhitEdRift's Avatar
Default Re: Oil change (florduhdude)
Well, just to update this with my status to MAYBE help someone. I took my car to the shop I work at and one of the guys that does oil changes rethreaded the hole and put a bigger bolt in. Works fine now. I suppose after so many oil changes it was about due for some fresh threads.
zomart
Oct 21, 2003 03:12 PM
Nos4R2
Jul 1, 2003 06:09 AM
hellas
Jan 18, 2003 09:53 PM
justinCO
Oct 7, 2002 02:37 PM
