Engine removal
Who here has removed the engine out of their 91 civic? How hard was it to do? What would you recommend cleaning the engine with? Hoping to take it apart this summer and clean the engine, and paint the engine bay. Any input?
disconnect every thing
unclip the wiring harnes at shock towers.
unhook shift linkage, and shift stabilizer
yank motor.
for more info use your friendly honda-tech search function
yank motor.
ive taken engines out. its not hard to do. just keep everything in separate zip lock bags. write clearly what it is and where you got it from. sometimes we forget what one bolt did compared to another. also, take pictures of the full engine bay. that way if you forget where something went or vacuum lines etc went you can just look at the pictures. have fun
blew mine up on sunday. we had it running by wednsday. pull it from the top if you can get a hoist. we pulled mine from the bottom and it sucked because u have to pull the front crossmember. but all in all, its not hard at all.
-spenc
-spenc
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback »</TD></TR><TR><TD CLASS="quote">disconnect every thing
yank motor.
you forgot to disconect the exhaust
Its not that hard. Took a friend motor out in 15 min.
Cleaning. Simple Green works well for that.
yank motor.
</TD></TR></TABLE>you forgot to disconect the exhaust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigDawwg6969 »</TD></TR><TR><TD CLASS="quote">I do have an engine hoist and a engine stand so that shouldn't be a prob. What do you recommend for getting road grime off of the bay?</TD></TR></TABLE>
Any kind of engine degreaser will work. Make sure you tape plastic bags on all of your harnesses in the engine bay. It won't hurt them much to get them wet, but better safe than sorry.
djnikko
Sep 18, 2007 09:14 AM
NatedoggAZ
Aug 13, 2007 08:23 PM
