axle quiz for you axle know-it-alls.
Old Feb 9, 2004 | 05:48 PM
BlackNoise's Avatar
Default axle quiz for you axle know-it-alls.
Hey, okay a couple quick questions. Do the GSR and the LS use the same axles? Do automatic axles differ from mannual axles? And last but not least, I am putting an LS motor into my hatch from an RS, which I'm not sure if it has ABS or not. I am putting together the swap and looking to buy LS axles, and the motor had ABS, my hatch does not. Does this matter in the long run? If you get all these right you win. Thanks for your help.
Old Feb 9, 2004 | 06:43 PM
BlackNoise's Avatar
Default Re: axle quiz for you axle know-it-alls. (BlackNoise)
hello?!
Old Feb 9, 2004 | 06:49 PM
m.'s Avatar
m.
hi
Old Feb 9, 2004 | 06:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: axle quiz for you axle know-it-alls. (10SPDHuffy)
post ***** post something useful.
I'm pretty sure you can use ABS axles in a car that does not have it. It shouldn't be a big deal. All Integra axles were the same, except for the ABS-equipped cars (most of them) had a toothed ring on the outboard joint which was read by a sensor on the back of the hub. The RS did not come w/ ABS, however.
Old Feb 9, 2004 | 07:00 PM
Dan GSR's Avatar
Default Re: axle quiz for you axle know-it-alls. (PatrickGSR94)
go ahead and use any 3rd gen integra axles
Old Feb 9, 2004 | 07:05 PM
BlackNoise's Avatar
so if i get a motor out of an RS that does not have abs and is a 5 speed, and use LS axels that had abs that was an automatic, in a hatch that does NOT have abs but is a five speed i should be a-okay? by the way...best most complicated question i have ever seen on honda-tech if i do say so myself
Old Feb 9, 2004 | 07:10 PM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">i should be a-okay? </TD></TR></TABLE>
Yes
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">most complicated question i have ever seen on honda-tech if i do say so myself</TD></TR></TABLE>
then you don't read enough
Old Feb 9, 2004 | 07:14 PM
BlackNoise's Avatar
Default Re: axle quiz for you axle know-it-alls. (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
then you don't read enough </TD></TR></TABLE>
No i just skip over the ones im not smart enough to answer which means i read the ones that say "how's this wing look?" but thats okay i still feel smart saying, "yes" or "no"...sometimes using the or if i'm feeling crazy. either way thanks for your help you made it easy for me.
Old Feb 9, 2004 | 07:15 PM
Dan GSR's Avatar
but if u stick around, and read, you can learn a thing or two here
Old Feb 9, 2004 | 07:16 PM
BlackNoise's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">but if u stick around, and read, you can learn a thing or two here </TD></TR></TABLE>
been here since 01 i read lots, only post if i feel the need, i just like to make fun of myself.
Old Feb 9, 2004 | 07:17 PM
jdmintegra1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">Hey, okay a couple quick questions. Do the GSR and the LS use the same axles? Do automatic axles differ from mannual axles? And last but not least, I am putting an LS motor into my hatch from an RS, which I'm not sure if it has ABS or not. I am putting together the swap and looking to buy LS axles, and the motor had ABS, my hatch does not. Does this matter in the long run? If you get all these right you win. Thanks for your help.</TD></TR></TABLE>
The axles (halfshafts) for autos and manuals are identical. However, the INTERMEDIATE SHAFT (the axle in between the two halfshafts), is DIFFERENT!!! I did an automatic to manual swap on my '94 LS...and although the auto and manual LOOK identical, the automatic is actually a little wider than the manual. Just wide enough to make it impossible to bolt on to the engine block. If you need one, just grab one from your local junkyard.
Old Feb 9, 2004 | 07:24 PM
BlackNoise's Avatar
Default Re: axle quiz for you axle know-it-alls. (jdmintegra1994)
booo!
Old Feb 9, 2004 | 09:00 PM
BlackNoise's Avatar
so then im not alright?
Old Feb 9, 2004 | 09:23 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">so then im not alright?</TD></TR></TABLE>
i dunno...it's hard to tell exactly what you're doing from your description. Are you putting a manual LS engine into your auto hatch? vice versa???
Old Feb 10, 2004 | 07:51 AM
BlackNoise's Avatar
im putting a manual ls engine into my manual hatch, but i dont know if the axles are from a manual or an automatic...i didn't know if it mattered or not.
Old Feb 10, 2004 | 09:49 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackNoise &raquo;</TD></TR><TR><TD CLASS="quote">im putting a manual ls engine into my manual hatch, but i dont know if the axles are from a manual or an automatic...i didn't know if it mattered or not.</TD></TR></TABLE>
Well the halfshaft should come w/ the engine I would think, and it already has the manual tranny on it too right? So just use any 3rd gen Integra axles.
Old Feb 10, 2004 | 10:26 AM
yes...if the LS engine already has the tranny connected to it, everything's fine. If everything's manual, there shouldn't be a problem...just make sure, like PatrickGSR said, that all the axles (halfshafts and intermediate shaft) are for a 3rd gen teg. You can't use the axles from your hatch.
BlackNoise
Feb 10, 2004 09:49 PM
asmallsol
Nov 27, 2003 06:49 AM
jumpmann23
May 28, 2003 01:56 PM
twotimesfour
Feb 11, 2003 09:42 AM
253EK
Sep 23, 2002 03:03 PM
