Going from Azenis to V700s for Auto-x
Old Feb 9, 2004 | 05:46 PM
Renegade's Avatar
Default Going from Azenis to V700s for Auto-x
I currently run the Azenis with Advance Design 500F/700R suspension, Camber adjustments and a 26mm rear sway bar.
Will there be a huge difference in the adjustments I will need to make to be run on the R comopounds. My front suspension is is set to about halfway and the rear is pretty soft ( I would say because of the sway bar ). This has given good results and control.
Can some people share their settings for R compounds or suggestions?
I know Road Racings is very different from autocross, but any experiences will help me make better decisions on adjustments and cut down on the tuning time.
Thanks
uNF$@#!'s Avatar
Default Re: Going from Azenis to V700s for Auto-x (Renegade)
baffled oil pan
Old Feb 10, 2004 | 02:41 AM
GreenBean's Avatar
Default Re: Going from Azenis to V700s for Auto-x (Soup ****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soup **** &raquo;</TD></TR><TR><TD CLASS="quote">baffled oil pan </TD></TR></TABLE>
Old Feb 10, 2004 | 03:58 AM
Ausmith's Avatar
The only thing I would look at changing would be to add a little more front camber (negative). The toe settings should be similar. Use tire pressure to fine tune.
If you have access to a tire pyrometer I would check the temps to see how the heat is distributed before you make any changes to the front camber.
Good luck - R compounds are fun!
Old Feb 10, 2004 | 06:47 AM
Renegade's Avatar
Default Re: Going from Azenis to V700s for Auto-x (Ausmith)
thanks for the info.
Congratulations on the new job!
Old Feb 11, 2004 | 02:29 PM
Ausmith's Avatar
Thanks!
onereving7
Suspension & Brakes
Oct 1, 2008 08:21 AM
EFstyle
14
Aug 23, 2007 06:18 PM
turbotime
Jul 14, 2004 03:43 AM
socalep3
Jan 5, 2004 08:19 PM
asmallsol
11
Sep 30, 2003 05:33 PM
