HELP: HOW DO I GET MY SPEEDO TO WORK?
Installed an ITR engine in my 88 crx. Using the YS1 cable tranny with QUAIFE lsd. The speed sensor from the 92-93 YS1 tranny isnt reading with the QUAIFE. Am I out of luck with getting the speedo to work ever? Is there another sensor i could buy or get so that the speedo will work? Any ideas?
Thanks in advance!!!!
i can turn the cable's end and make the speedo work with my fingers so i know the cable and cluster work. it worked 'till i did the swap. the speedo gear itself isnt fitting into the grooves in the diff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions »</TD></TR><TR><TD CLASS="quote">maybe the cable is busted??? or its not in the cluster good enough</TD></TR></TABLE>
azazello
Sep 16, 2010 10:39 AM
