Free CEL light with install of RSR EX MAG
Old Feb 9, 2004 | 04:01 PM
dc2lun's Avatar
Default Free CEL light with install of RSR EX MAG
So I finally installed my RSR EX MAG, I've had it since november. Drift speed didn't send me the gasket/bolt kit. Bad guys to deal with, kept giving me the run around. So I called Koji at RSR, great guy .
Anyhow, I installed it at work today. During the install I had a hard time getting the cat converter bolts off, I got 2 off had to saw the last one off. So now there is only 2 bolts holding the cat, I figured it would be ok since I'm putting in a Carsound Cat soon. Anyhow my question is would a small exhaust leak like that cause the CEL light to come on? Also while the exhaust was disconnected the Cat was hanging kinda tugging on the O2 sensor wire, maybe something came lose?
And another thing, I noticed there was a O2 sensor on my cat. I thought 94 integra's don't have O2 sensor in the Cat?
Thanks in advance for any help!
Edit: My friend who owns a VW has this computer program and cable that connects to his car. He uses to check engine codes. For ODB-2 VW, Im assuming that won't work for my car? Where is my plug for checking CEL lights?
Modified by dc2lun at 8:28 PM 2/9/2004
Old Feb 9, 2004 | 04:26 PM
swanny's Avatar
Default Re: Free CEL light with install of RSR EX MAG (dc2lun)
same thing happened with mine but the wires ripped completely out. id disconnect the wires from the O2 and make sure there all in and then use some sort of glue and glue them in.
Old Feb 9, 2004 | 04:34 PM
neo1z's Avatar
Default Re: Free CEL light with install of RSR EX MAG (xy swany)
There is a little blue clip you have to jump under the passenger side dash. If somebody has a pic, I am sure the gentleman in this post would be much appriciative to see it.
Old Feb 9, 2004 | 04:46 PM
dc2lun's Avatar
Default Re: Free CEL light with install of RSR EX MAG (neo1z)
I most definetly would. It would be a great help.
Old Feb 10, 2004 | 03:26 PM
dc2lun's Avatar
bump for some help.
stacdizzle
Honda Civic (2001 - 2005)
Dec 4, 2013 10:14 AM
iheartmyej8
Feb 27, 2009 05:24 PM
Tyler Con
Jan 6, 2008 11:45 PM
mystikz2002
Sep 23, 2005 06:20 PM
paulyman
Jan 21, 2002 02:49 PM
