h&r race springs with 205/50/15
anyone running race springs on their teg with 205/50/15 tires? are there rubbing issues with wider tires and a big drop? i have h&r race springs and i need new tires but im not sure if i should get 205/50 or 195/55. also, which tire would be better. yoko es100 or falken 512. how many miles would i get out of the tires. tia.
205/40-16 is an inch smaller than stock and much less likely to rub (but more likely to get bent rims due to tiny sidewall).
I have a 3" drop w/ 205/50 ES100's on stock wheels, no rubbing issues whatsoever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O1Dc2 »</TD></TR><TR><TD CLASS="quote">patrickgsr94: how many miles you got on ur es100s since u bought them? </TD></TR></TABLE>
I am running no camber kits, and about -2.5 camber in front. After 15K miles I noticed some wear on the inside edges, so in an effort to extend the lives of the tires till I graduate in May, I flipped the tires around on the wheels and remounted them so the previously outside edges are now on the inside. It's been almost 25K miles now since I bought them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O1Dc2 »</TD></TR><TR><TD CLASS="quote">anyone running race springs on their teg with 205/50/15 tires? are there rubbing issues with wider tires and a big drop? i have h&r race springs and i need new tires but im not sure if i should get 205/50 or 195/55. also, which tire would be better. yoko es100 or falken 512. how many miles would i get out of the tires. tia. </TD></TR></TABLE>
I'm running H&R race springs with 205/55/15 tires. It does rub sometimes when turning sharp, such as in a parking lot. Oddly, it doesn't rub when turning really hard. The rub really doesn't bother me though. I'd recommend 205/50 or lower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O1Dc2 »</TD></TR><TR><TD CLASS="quote">ti3d in: got any pics of ur car? </TD></TR></TABLE>
Yep. Look at those big tires!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">205/40-16 is an inch smaller than stock and much less likely to rub (but more likely to get bent rims due to tiny sidewall).
I have a 3" drop w/ 205/50 ES100's on stock wheels, no rubbing issues whatsoever.</TD></TR></TABLE>
how does the rim get bent?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4 »</TD></TR><TR><TD CLASS="quote">
how does the rim get bent?</TD></TR></TABLE>
Less rubber cushion I suppose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FrostWhiteDC4 »</TD></TR><TR><TD CLASS="quote">he said something about sidewalls....
exactly. the smaller sidewall leaves less tire to absorb impact from bumps etc. the recommended 16" size for integras is 205/45/16
Also on a 15" rim, 205/55 is too big as well. and quick question... did you buy that car from a guy named Vu?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLB SMZ »</TD></TR><TR><TD CLASS="quote">
Also on a 15" rim, 205/55 is too big as well. and quick question... did you buy that car from a guy named Vu?</TD></TR></TABLE>
thanks sergio, i got it now.
Hahaha...Vu is my brother. He handed the car down to me.
O yeah that neighborhood you see in the pics is in Corona right off Promenade and Cresta.
Yeah i got some H&R sport springs and some tokcio adj. shocks and they rub like a mother.... if i am going fast and hit a bump it rubbs. or if i turn hard. i adj. my shocks stiffer but that did not help much just alittle.... i am on stock 14 ls wheels ... but my tires are really big i guess so that is maybe why. Im about to put my 17" back on my car cuz winter is almost over so i hope it stops rubbing cuz the wheels are smaller
Mybishi
Oct 4, 2006 10:14 PM
weakGOODJunKieS.com
Apr 5, 2003 10:05 PM
