Can i use stock motor mounts?
Old Feb 9, 2004 | 02:23 PM
89-ef's Avatar
Default Can i use stock motor mounts?
I'm going to drop a b18a1 into my 88 civic hb i was wondering if i could use the oem mount from the integra or do i got to buy some aftermarket ones? And wut wiring harness do i use?
Old Feb 9, 2004 | 03:31 PM
speed_racer012's Avatar
Default Re: Can i use stock motor mounts? (89-ef)
I'm going to be doing the same thing wouldn't mind knowing about the wiring harness.
Old Feb 9, 2004 | 03:40 PM
-KangaRod-'s Avatar
you can ghetto cut your mounts, but you'll probably want to buy a mount set. they are cheap enough. The wiring will be easy as an xlaxed bowel movement.
Old Feb 9, 2004 | 03:51 PM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: (-KangaRod-)
Use the harness thats on the car now and modifly it to work with the B18
Old Feb 9, 2004 | 05:08 PM
ShiroX's Avatar
Default Re: (TSRperf)
it depends on what model civic you have
is your car already multiport? if not you will have to do a multiport conversion.
you will have to buy a mount kit...it makes things easier....i would get same brand and but thier shift linkage also. every maker of different kits positions the motor differently therefore finding the proper shift linkage can become a problem
so stick with the same brand
Old Feb 10, 2004 | 03:52 PM
89-ef's Avatar
the model is dx and its duel. i think imma half to do the mpfi conver. u guys know a cheap mount kit? and i thought i could use the ls shift linkage with a lil cutting. wut it b betta if i used a si harness?
JLefevers
Mar 29, 2006 10:18 PM
MUGEN_B16CIVIC
Jan 14, 2004 06:47 PM
drewlee
Feb 24, 2003 09:03 AM
kenepo
Feb 20, 2003 05:52 AM
kahren
Sep 28, 2001 06:16 AM
