Boost + bike??
Old Feb 9, 2004 | 12:13 PM
SOHCMAN's Avatar
Default Boost + bike??
Who all has done it and how? What will be the difference when on a carbed engine? Are there any good sites about this? And is turboing the best option of is belt driven feasable?
thanks for any info!!
sohc
Old Feb 9, 2004 | 12:14 PM
Kris's Avatar
Default Re: Boost + bike?? (SOHCMAN)
The only bike worth turboing is a busa IMHO.
Old Feb 9, 2004 | 12:27 PM
Turbogixxer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCMAN &raquo;</TD></TR><TR><TD CLASS="quote">What will be the difference when on a carbed engine</TD></TR></TABLE>
Carbs are harder to tune with FI because you have *basicly* one setting for fuel through out the powerband. Fuel injection, you can change the fuel maps at almost any RPM. You can do it, but you have to put the time in to tuning it right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCMAN &raquo;</TD></TR><TR><TD CLASS="quote">And is turboing the best option of is belt driven feasable?</TD></TR></TABLE>
Bikes (sportbikes) do not belt drives like cars do, thats why people turbo them, it is easier.
Old Feb 9, 2004 | 01:54 PM
tonydatyga's Avatar
Don't you know it is impossible to turbocharge a carb'd engine?
Old Feb 9, 2004 | 05:52 PM
D2N's Avatar
D2N
Default Re: Boost + bike?? (tonydatyga)
Seems like alotta misinformation here.
You can turbo a carbed engine and there are belt driven superchargers on bikes as well.
Carb tuning is no different than mapping a piggyback fueling system on an injected bike.
Go to Psychobike.com, SuperKaos.com to name only 2 (there are several boards that have this info).
Old Feb 9, 2004 | 06:25 PM
theSYNDICATE's Avatar
From: Derek Jeter drinks wine coolers,, The Nation, USA
Default Re: Boost + bike?? (Kris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kris &raquo;</TD></TR><TR><TD CLASS="quote">The only bike worth turboing is a busa IMHO.</TD></TR></TABLE>
So I guess this bike wasnt worth turboing either'
http://cgi.ebay.com/ebaymotors...49999
Theres a guy on here with a turbo'd Busa. And there is a guy on http://www.sportbikes.net also
Old Feb 9, 2004 | 07:09 PM
rioninja's Avatar
My cbr f4i will be turbocharged by the end of the year.
Some people would argue that its pointless to try to make a civic go fast,
so all the people that ask "why are you wasting your time turboing a 600"
can blow me.
I have a crazy idea on using a power commander for fuel management,
in a 'vafc hack' style setup. If that fails, ill probably just use my spare
standalone i have sitting around. http://www.perfectpower.com
The hardest part is going to be finding space for everything.
Old Feb 9, 2004 | 07:22 PM
90Ninja
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">Don't you know it is impossible to turbocharge a carb'd engine?</TD></TR></TABLE>
It is possible to turbocharge a carburated vehicle. I have seen many Mustangs and Camaros turbo'd and they were carburated. It may just be a little harder to tune. I don't know how hard it would be, I have never done it, but I have seen it done.
Old Feb 9, 2004 | 07:25 PM
Kris's Avatar
Default Re: Boost + bike?? (91 Teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91 Teg &raquo;</TD></TR><TR><TD CLASS="quote">So I guess this bike wasnt worth turboing either'
In my opinion, absolutely not.
Old Feb 10, 2004 | 05:48 AM
tonydatyga's Avatar
Damn, my misinformation didn't work this time. I think there needs to be a sarcasm smiley since nobody here seems to pick up on it. I mean come on!
Old Feb 10, 2004 | 06:40 AM
busa1300's Avatar
I had two turbo charged Cbr900's (94, 96) They were great fun. Only 180 Hp, but very smooth power. The kits were designed on a bike running Foumula USA, bnefore they changed the rule . It was very managable in the corners and was a great street set up. Not too much Hp but enough. Kit was made by Team Mr. of El Paso TX.
Old Feb 12, 2004 | 05:55 PM
gsrguy's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">Don't you know it is impossible to turbocharge a carb'd engine?</TD></TR></TABLE> WTF are you taking ABOUT?
Old Feb 12, 2004 | 07:21 PM
tonydatyga's Avatar
Default Re: Boost + bike?? (gsrguy)
read the entire thread
Old Feb 13, 2004 | 01:04 PM
Pio's Avatar
Pio
Theres a guy on here with a turbo'd Busa. And there is a guy on http://www.sportbikes.net also</TD></TR></TABLE>
i use to see that bike on the streets in phila nice *** bike and fast as hell never seen a bike stay with him. very clean bike
Old Feb 13, 2004 | 08:10 PM
xci_ed6's Avatar
Default Re: Boost + bike?? (Pio)
Carb'd setups:
Draw through:
+carb works same as N/A
-can't have intercooler
-fuel moving through turbo, requires turbo w/ special seals.
-carb can freeze under 50* F ambiant
Blow through:
+can have intercooler
-need airtight carb
-need FPR and harder to tune
-can end up w/ fuel weeping past carb seals
I recomend FI only. Bikes would be better setup for turbos, IMO, if the intake was on the front of the motor.
-Dustin
Old Feb 14, 2004 | 01:32 AM
markdman's Avatar
What about the internals? do people just keep them stock?
Old Feb 14, 2004 | 07:32 AM
busa1300's Avatar
Default Re: (markdman)
Mine were all stock injternals except the clutch springs and 96 had turbo pistons. But then they were only running around 190hp. Much more then that and you would have to have connecting rods and valve springs.
My hayabusa is internally stock except for clutch springs and the base gasket. They internals built a lot more heavy duty. They are good for about 350Hp before you need connecting rods and valve springs.
Old Feb 14, 2004 | 10:20 AM
xci_ed6's Avatar
Default Re: (busa1300)
wtf? why valve springs? so light boost opens them or something?
-Dustin
Old Feb 15, 2004 | 09:56 AM
busa1300's Avatar
light boost, no around 17 psi or so will keep them open.
Old Feb 15, 2004 | 02:53 PM
xci_ed6's Avatar
cool
Old Feb 16, 2004 | 05:31 AM
stumbler's Avatar
Default Re: (krustindumm)
anyone know the average price of a cbr, 600/900/929 turbo kit, but more specifically a 929? and where to find them?
Jasper_db1
Honda Motorcycles
Mar 16, 2007 03:00 PM
life sux die
Honda Motorcycles
15
Feb 19, 2007 04:10 PM
BBailey
Honda Motorcycles
Mar 12, 2004 01:43 PM
.ti s'taht .rolyaT
Honda Motorcycles
14
Mar 7, 2004 04:21 PM
IloveNewt
Honda Motorcycles
May 7, 2003 01:09 PM
