Factory swaybars and models
Old Feb 9, 2004 | 11:16 AM
HondaPartsHero's Avatar
Technical Hero
Default Factory swaybars and models
Anyone have a definitive listing on 88-91 Civic/CRX hatch, 4dr, wagon and which models came with swaybars. Or if this was an option or model specific. The reason is I was wanting to do the ES master kit on my 89 CRX Si and was needing a set of front and rear LCA's to replace the bushings in off the car because my shock bolts on the rear are all frozen. And i assume that the models that didn't have factory sways didn't have the bolt in part on the rear LCA's.Wasn't sure if anyone here knew or not.
Old Feb 9, 2004 | 12:27 PM
ironchef25's Avatar
Default Re: Factory swaybars and models (yebabee)
regarding your sig: hey isnt a b a b?.. not b a b a
Old Feb 9, 2004 | 02:21 PM
XrcR6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee &raquo;</TD></TR><TR><TD CLASS="quote">And i assume that the models that didn't have factory sways didn't have the bolt in part on the rear LCA's.</TD></TR></TABLE>
That's correct, you'll definitely need rear LCA's from a car that came with a rear swaybar.
Not sure on the other models, but the CRX-Si should have been the only one with 15mm rear bar. HF/DX rear LCA's won't have the threaded holes for the endlinks. Also, you would have to make sure to get '89-'91 CRX-Si LCA's. The '88 Si, will utilize the eyebolt (Type-R) style rear shock attachment, rather than the fork-style on your '89.
Old Feb 9, 2004 | 07:17 PM
Technical Hero
Default Re: Factory swaybars and models (ironchef25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">regarding your sig: hey isnt a b a b?.. not b a b a </TD></TR></TABLE>
that might be for another code but mine is the classic 30 man code for contra.
Old Feb 9, 2004 | 09:08 PM
ironchef25's Avatar
yah that game. wasnt it up up down down left right left right a b a b
Old Feb 9, 2004 | 09:30 PM
EG8R's Avatar
Isn't it B A Select Start? I'm pretty sure it is!!!
I have a song with it in it....
Old Feb 9, 2004 | 11:20 PM
C_I_V_I_C's Avatar
Default Re: Factory swaybars and models (skelly ed6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 &raquo;</TD></TR><TR><TD CLASS="quote">Isn't it B A Select Start? I'm pretty sure it is!!!
I have a song with it in it....</TD></TR></TABLE>
Hell yeah it was select start
Old Feb 10, 2004 | 06:33 AM
Technical Hero
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironchef25 &raquo;</TD></TR><TR><TD CLASS="quote">yah that game. wasnt it up up down down left right left right a b a b </TD></TR></TABLE>
i checked out some code sites and it says that UUDDLRLRABAB is for unlimited men but i've never tried that code.
Old Feb 10, 2004 | 06:57 AM
ironchef25's Avatar
i checked out some code sites and it says that UUDDLRLRABAB is for unlimited men but i've never tried that code.</TD></TR></TABLE>
hahahhahh see.. i knew it. hahhhahahha it feels good to be right.. hahahahahah jk. time to dust my old nes system and try the codes.hahahahahahhah
Old Feb 10, 2004 | 07:07 AM
4drEF's Avatar
Keyboard Humorist
Default Re: Factory swaybars and models (XrcR6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XrcR6 &raquo;</TD></TR><TR><TD CLASS="quote">
Not sure on the other models, but the CRX-Si should have been the only one with 15mm rear bar. HF/DX rear LCA's won't have the threaded holes for the endlinks. Also, you would have to make sure to get '89-'91 CRX-Si LCA's. The '88 Si, will utilize the eyebolt (Type-R) style rear shock attachment, rather than the fork-style on your '89.</TD></TR></TABLE>
You also have to figure out how to attach the brackets the the chassis. From what I have been told (I asked the question a while ago) the holes are there, but they aren't threaded. It's not something easy that you can slip a nut behind either. You would have to cut a hole in the chassisframe rail and somehow get a nut behind it.
Old Feb 10, 2004 | 07:13 AM
phan's Avatar
Default Re: Factory swaybars and models (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
You also have to figure out how to attach the brackets the the chassis. From what I have been told (I asked the question a while ago) the holes are there, but they aren't threaded. It's not something easy that you can slip a nut behind either. You would have to cut a hole in the chassisframe rail and somehow get a nut behind it.</TD></TR></TABLE>
this is correct. i put a DA INTEGRA rear sway bar on the car and had to weld the brackets to the chassis as there are holes but no threads.
Old Feb 10, 2004 | 02:15 PM
XrcR6's Avatar
He should be OK in the bracket department. I think he said that he has an 89 Si, so it already came with a swaybar and the brackets and the threaded holes...
B96v6
10
Dec 24, 2005 05:55 PM
Black R
Jan 21, 2005 06:12 AM
DIY_Racing
13
Mar 24, 2003 03:20 AM
Lo-Buck EF
Jan 22, 2003 07:50 AM
