a few eg dash swap questions....................
Old Feb 9, 2004 | 10:03 AM
Grip's Avatar
Default a few eg dash swap questions....................
in my car right now is a blue cx dash and i just picked up a mint black cx dash from forcfedcivic ...i was lookin at the back of the black dash to see if i could see where the dash mounting bolts go to make an easier swap...but there are alot of holes and im havins some trouble finding holes that mount the dash compared to holes that mount the dash wiring harness..does anyone know about how many dash mounting bolts there are? where they are located and about how long did it take you guys to swap dash's?
i know once i get the blue dash out is when i swap the grey stereo/climate control surround..anything else i should look out for when doing the swap to make it a little easier for me?..yes i have common sense and could use it when doing the swap but even common sense takes a while when you have to hunt down the4 bolts with out knowing where to look excatly or around
Old Feb 9, 2004 | 10:08 AM
itsm3paul's Avatar
Default Re: a few eg dash swap questions.................... (Grip Driver)
well from what i recall there are three bolts in the middle and 2 on the sides those are the main bolts you should be looking at also behind your ashtray has a bolt there too so 4 bolts total from what i remember easyest way to do it is
taking out your stearing wheel
take out your cluster
climate
deck
your ashtray covers and **** like that
then unscrew the four bolts
or if you see more then that holding the dash up then un screw those
uh you should be good from there
correct me if im wrong but thats what i remember
Old Feb 9, 2004 | 10:19 AM
Grip's Avatar
Default Re: a few eg dash swap questions.................... (itsm3paul)
thanks..ive learned from lookin at the back of the new dash that there is one bolt on each end of the dash under each little black cover..1 bolt under the big vent in the middle of the dash...and 1 behind the ash tray...yea i figured i should take out the climate control,radio,guage cluster,and all small acessories
Old Feb 9, 2004 | 10:21 AM
ej1 pilot's Avatar
shoulda gone with the spray paint
Old Feb 9, 2004 | 10:24 AM
X2BOARD's Avatar
Default Re: a few eg dash swap questions.................... (CXinthemaking)
You will need to swap the climate controls, etc while BOTH dashes are out.... the screws are mounted in the back....
Old Feb 9, 2004 | 10:25 AM
Grip's Avatar
Default Re: a few eg dash swap questions.................... (X2BOARD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by X2BOARD &raquo;</TD></TR><TR><TD CLASS="quote">You will need to swap the climate controls, etc while BOTH dashes are out.... the screws are mounted in the back....</TD></TR></TABLE>
yea common sense tells me that
and for the guy who said paint it thats ghetto and im not
Old Feb 9, 2004 | 10:28 AM
Grip's Avatar
so far it seems pretty easy....i searched and found rodrez's thread about blue to black eg dash swap..kind of informative but not really
Old Feb 9, 2004 | 10:58 AM
X2BOARD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grip Driver &raquo;</TD></TR><TR><TD CLASS="quote">
and for the guy who said paint it thats ghetto and im not </TD></TR></TABLE>
Well... I've done other cars and many cars are 'snap fit' in that department... I was surprised to see honda's did it w/ screws....
BTW... as far as paint... I always thought that was ghetto, but it was only a few months ago that I found out MY dash had been painted from blue to black.... the quality was GREAT to my surprise... very impressed. It sounds ghetto, but even avid car guys had no idea it was painted... even after they touched and prodded the dash. After I told them... it was like...
Old Feb 9, 2004 | 11:28 AM
Grip's Avatar
yea i too have seen some painted dash's and parts..they looked allright..but thats just not me...
im gonna go and try to do this thing (if i come across any problems ill post them up but i doubt i wont be able to figure anything out on my own)..its 2:27pm now..lets see how long it takes
Old Feb 9, 2004 | 01:19 PM
X2BOARD's Avatar
Took me about 90 mins to remove my dash the first time I did it.... and I did it alone....
Now my windshield wipers don't work and the dash cracked where the VIN tag is....I know better now that's it's too late....
Old Feb 9, 2004 | 01:51 PM
MissLady's Avatar
rodrez did a nice write up on dash swaps in the arvhice thread....i thik its still there
Old Feb 9, 2004 | 03:26 PM
Grip's Avatar
Default Re: a few eg dash swap questions.................... (MissLady)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MissLady &raquo;</TD></TR><TR><TD CLASS="quote">rodrez did a nice write up on dash swaps in the arvhice thread....i thik its still there </TD></TR></TABLE>
yea i found rodrez's thread..not informative at all..mostly pics and dumb questions
well it took me almost excatly 2 hours to remove the blue dash and have the black dash in and all put together...the hardest and longest part was swapping vin plates and making it look like it was never touched ...other then that it was pretty damn easy..i think i could do the next one in an hour tops...everything works perfect on my car after the dash swap..but i did manage to break that little clip under my climate control that holds the cable..so now my heat is stuck on the hot position (good thing its winter)..over the summer ill get a new one and a jdm front for it
myblackhatch
Oct 8, 2006 07:59 PM
1quickvr4
22
May 18, 2005 08:04 PM
civichb
Sep 10, 2001 03:40 PM
