AEM V2 at the track
Old Feb 9, 2004 | 08:59 AM
luiggie's Avatar
Default AEM V2 at the track
Do you have the same bad experience with AEM V2 into RSX-S as me:
Good dyno #'s but at the track you are 1-2 mph slow than stock.
Stock mph(1/4):
91-92mph
AEM V2(1/4):
89-90mph
But at the dyno is gain of 10WHP+ and 10lbs torque+
Anyone experience the same result with AEM V2?
PS
My only mod is AEM V2 in 2003 RSX-S.
Old Feb 9, 2004 | 09:27 AM
GreenR's Avatar
Default Re: AEM V2 at the track (luiggie)
Off day, maybe or different tires?
Old Feb 9, 2004 | 09:36 AM
luiggie's Avatar
Default Re: AEM V2 at the track (GreenR)
Ok, here is the scenario.
With the same tires.
I went to the track with my S bone stock and the #'s :
15.4@91.9 , 15.5@91 ,15.4@92
then 3 weeks later I went with the AEM V2 and everything is the same:
15.5@90 15.6@89
then I went again with AEM V2 to see if the problem was a "bad day at the track":
15.6@90 15.5@90
The numbers are a little high but if u see my sing I'm in Puerto Rico and here the #'s are different. EG
US 15.0 in PR is 15.3~
Because of the humidity and weather conditions.
But at the dyno I gain 10~ whp
AEM V2 172whp @ 127 torque
stock 160whp @ dont remember the torque.
Opinions please.
Old Feb 9, 2004 | 10:07 AM
8600RPM's Avatar
next time at the track ....try this...
put a bag of ice on your V2 in between passes.
my only guess is that you arent letting your car cool down enough between passes, and since the V2 isnt a cold air design, its drawing in all that heat being held in by the engine compartment, that isnt having enough time to be released because you arent driving your car around and taking in air except when you are moving down the track when its too late.
other than that... the 60' time would be nice to know so I could help you more
Old Feb 9, 2004 | 10:21 AM
luiggie's Avatar
Default Re: AEM V2 at the track (8600RPM)
Ok!
I stop 15 mins in every run to cool down the engine.
About my 60' when I compare the papers:
Stock:
15.4@91.9 2.64(60') 10.15(1/8) serveral runs like this
AEM V2:
15.5@90 2.49(60) 10.10(1/8) all the runs are similar
As you can see everything is ok til the car is runing in 3rd gear, it slow down instead of continuing gain mph's.
Thanks for replying I'll be listening. Today I'm going to install an AEM CAI of my friend to make some test but I'll like to know if anyone is experiencing this kind of prob with AEM V2.
Old Feb 9, 2004 | 12:02 PM
GreenR's Avatar
Could be your reaction times.
Old Feb 9, 2004 | 12:11 PM
jaydub's Avatar
haha don't get mad at us because we can't give you a good answer!
Old Feb 9, 2004 | 12:18 PM
andyep3's Avatar
When you did your dyno run, was the hood open? Did they have fans blowing on the engine bay?
That could be the reason why it performs well on the dyno and not as well on the track. Although
the difference in times/trap speed still seems a bit odd...
Old Feb 9, 2004 | 12:29 PM
luiggie's Avatar
Default Re: (andyep3)
Yes I did the dyno with open hood and a fan blowing to the engine.
GreenR:
At the track the clock begin to run when you launch the car not when the green ligth appear because is a test runs.
jaydub:
Don't worry I'll keep track of this post.
I have a theory but I'm not sure, my theory:
AEM V2 sucks when the climatological and weather environment(humidity) is like our island(Puerto Rico)
Keep posting and thanks!
Old Feb 9, 2004 | 01:01 PM
krystar's Avatar
hey luiggie, when u cool down, do u open yer hood? that's what I do w/ my V2. let it cool down till I can't feel that the intake is warm to touch. bag of ice trick would work too if you need it faster.
yea those ET's are alot slower than ours. I don't think any kind of comparison would be valid. the 60's are also slower than us over here. worst i've ever gotten on V2 was 2.4 something. but again, it's probably not valid to compare.
Old Feb 9, 2004 | 02:09 PM
luiggie's Avatar
Default Re: (krystar)
Thanks Krystar
I open the hood when I finish a run wait ~15 mins and run again, but I didn't try Ice bag trick, I'll try it.
Is frsutrating ET here in PR.
Can you post your ET diference with the AEM V2 .
Old Feb 9, 2004 | 03:21 PM
8600RPM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreenR &raquo;</TD></TR><TR><TD CLASS="quote">Could be your reaction times.</TD></TR></TABLE>
I hope that was a joke
Old Feb 9, 2004 | 03:30 PM
GreenBean's Avatar
Do you have a friend that would lend you a CAI for a day at the track?
That would be some good comparison #'s there.
Old Feb 9, 2004 | 03:52 PM
luiggie's Avatar
Default Re: AEM V2 at the track (GreenBean)
Yes, rigth now I'm going to my friend house to take the AEM CAI for some test.
I'll let u know!
Old Feb 9, 2004 | 04:00 PM
8600RPM's Avatar
we did a similar test at a MidWest ClubRSX meet this past summer...
One Type S had an AEM CAI, the other had an AEM v2, and no other mods, they both were within a tenth of each other pretty much all day, it was about 80 degrees that day with a pretty good amount of humidity.
however, each car/driver/lane/track conditions are not always the same, so its hard telling really
Old Feb 9, 2004 | 08:58 PM
K1R's Avatar
K1R
Default Re: (luiggie)
whats the 1/8 speed?
Old Feb 10, 2004 | 03:43 AM
luiggie's Avatar
Default Re: (K1R)
When I ran bone stock mph sensors of 1/8 fail , in the papers show only the ET not the mphs But I have the paper of the run with AEM V2 I'll check and post the mphs later beacause is at home.
Old Feb 10, 2004 | 06:36 AM
theclutchpoppa's Avatar
damn we trapped 96mph with just a Injen CAI....everything else BONE STOCK.....
Old Feb 10, 2004 | 05:41 PM
DC5ITR329's Avatar
Make sure you reset your ecu when you add the cold air intake. That might be your problem.
Old Feb 10, 2004 | 05:54 PM
Chemicalviper's Avatar
Default Re: AEM V2 at the track (aznbo1626)
You guys realize that short-ram and cold air intakes do have slightly different hp ratings, but they make more hp in different areas -
Heres an old *** link for ya http://www.tprmag.com/issue/1/1_intakes.shtml Perhaps where they make power might be the problem? if you make up more in midrange but lose some in top end that will effect qtr mile because your always in top end when shifting redline
Old Feb 11, 2004 | 04:40 AM
luiggie's Avatar
Yes I reset the ECU when I install AEM and also between runs at the track. But I already have the AEM CAI(V1) that a friend gave it to me to perform some test.
Again: The problem is at the track not at the dyno. Seems that the problem is at high mph, maybe because of the way that the air enter to the filter or AEM V2 doesn't like Puerto Rico's environmnet.
Old Feb 11, 2004 | 03:18 PM
AU K20A2's Avatar
Your times look low stock.
Old Feb 12, 2004 | 09:16 AM
luiggie's Avatar
Default Re: (AU K20A2)
Read all the history, I'm in Puerto Rico, here the ET's are different ex:
15.5 in US is 15.8 in PR.
Old Feb 23, 2004 | 02:44 PM
Battle Mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luiggie &raquo;</TD></TR><TR><TD CLASS="quote">Ok!
Stock:
AEM V2:
Thanks for replying I'll be listening. Today I'm going to install an AEM CAI of my friend to make some test but I'll like to know if anyone is experiencing this kind of prob with AEM V2.</TD></TR></TABLE>
your answer is in front of you....the lower your 60ft, the lower your mph...
Old Feb 28, 2004 | 03:20 PM
RSX-TC's Avatar
What is the advantage of a V2 over a cold air induction or ram air?... sorry I'm a noobie to this stuff
K20Ahondas
May 23, 2011 07:49 PM
delsoltuga
32
Nov 18, 2004 04:46 PM
luiggie
15
Feb 24, 2004 12:13 PM
luiggie
Jan 21, 2004 04:08 PM
