clutch problem....
Old Feb 9, 2004 | 08:28 AM
hatch_22si's Avatar
Default clutch problem....
i'm not sure wut's wrong with my clutch. i have a h22 powered eg hatch si and the clutch has been slipping. it's an act clutch and i've heard people say that act clutches dont need to be broken in. it's wierd...on launches and down shifting the clutch doesn't seem to grab....it's just revs like it's slipping and then takes off....
Old Feb 9, 2004 | 08:36 AM
mattssi's Avatar
Default Re: clutch problem.... (hatch_22si)
All clutches need breaking in! Even ACT. Did you get this clutch new?
Old Feb 9, 2004 | 08:39 AM
Ricey McRicerton's Avatar
Default Re: clutch problem.... (mattssi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattssi &raquo;</TD></TR><TR><TD CLASS="quote">All clutches need breaking in! Even ACT. Did you get this clutch new? </TD></TR></TABLE>
Ummm...how about no?? They need to be alligned correctly, and usually your first hard shift will do this. I've put in a couple of clutches and never once broken one in.
Old Feb 9, 2004 | 08:45 AM
Maintenance's Avatar
Default Re: clutch problem.... (Ricey McRicerton)
Did you install the clutch yourself? If its slipping, I would take out the tranny and check out the clutch. That's the only way to find out for sure if something is wrong.
JDM_EH2
Sep 10, 2005 11:34 PM
hondaracing1
Jun 22, 2005 11:15 AM
DANgerous
Apr 4, 2004 01:37 PM
rody084
Mar 23, 2004 06:00 AM
