Vaccum hoes question?
Guest
Posts: n/a
Hey was sup guys - I'm running a b16a and added a Type R throttlebody and intake manifold. The thing is that on the bottom of the R throttle body it has two connectors (left and right) that you hook up to vaccum hoses. On my b16 T/B it had a little valve on top where near the TPS you hook up the smaller hoses to. The hoses are running from this black cylinder devices under my fuel filter. I need some tech help I'll get a pic up and running with in the hour. I looked in my helms book and i'm lost can't find any real info on it.
http://www.snapfish.com/thumbn...53974
here is my email name - rangeles@ortc.com and my password is b18cgsr
Modified by range at 10:23 AM 2/9/2004
Modified by range at 10:24 AM 2/9/2004
i keep my hoes hooked up by keeping my pimp hand strong..
i keep my hoses attached in the car..
sorry, but you did it over and over again, i had to say something..
and that black canister is known as the evap canister I assume. I don't have one(took it out).. It, supposedly, should just help with emissions stuff.. Other than that, I can't really discern a question from your post..?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mstewar »</TD></TR><TR><TD CLASS="quote">i keep my hoes hooked up by keeping my pimp hand strong..
If the vaccum hoes [sic] can suck the chrome off a trailor hitch, send her over my way.
Those two hoses on the bottom aren't vacuum lines. They're for coolant. 3/8" hose.
The long nipple on top is for the EVAP purge. 5/16" or 1/4" hose.
Guest
Posts: n/a
I got a chance to read up on the EVAP system. It's the hoses coming from the charcoal canister. I noticed that on my Type R manifold there is a valve on the back right in the middle that my friend capped off - wondering if maybe perhaps something should be plugged up.
Braco11
17
Feb 12, 2008 12:32 PM
90crxdriver
13
Feb 13, 2007 04:14 PM
cjames235
Jun 10, 2004 06:09 AM
