after i start the car it idles then the idle ceases and then dies
Old Feb 9, 2004 | 02:08 AM
darkmarc's Avatar
Default after i start the car it idles then the idle ceases and then dies
info about motor etc
stock d16z6 put back into civic after gsr swap...car is a 95 civic ex coupe...everything is on except for the cat because of the extension added to it in order for the gsr to bolt on(i doubt its that because i have cranked over motor without the cat hooked up)...oh yea and the pulleys for ac power steering arent hooked in....i also am reading a vtec solenoid code(can that prevent to cease after)...the mian thing is i crank the car over it starts idle sounds stock and fine...but then its drops and then the car idles so low it stalls and dies....everything i see around says iac, vacccum, blah i was wondering if the cat and the vtec soleoid also prevents from starting and idleing stock...pelase any help would be great...i dont want to send to shop and waste money if i can do it myself
Old Feb 9, 2004 | 02:28 AM
specktur's Avatar
Default Re: after i start the car it idles then the idle ceases and then dies (darkmarc)
As much as you say, "Blah", it sounds like IAC to me.
Lenne
Jul 16, 2015 07:25 PM
TwistedEX
Jun 18, 2009 06:37 PM
Thateguhate
Dec 7, 2008 02:36 PM
The Dirty EJ1
Mar 27, 2006 10:56 PM
EggEX2000
Apr 26, 2003 08:23 PM
