2000 accord check engine light
Old Feb 9, 2004 | 01:23 AM
1998hondaaccord's Avatar
Default 2000 accord check engine light
I had the check engine light come on my 2000 accord ex v6 had the code read (p1491) came up. Code interpeted this "EGR Valve Lift Insufficient Detected" .
Few questions?
1.DOes this mean i need a new EGR VALVE? Is it the egr valve?
2.Is it possible that could be cleaned?
3. Is there speacial things to do to install this?Can i reuse the gasket , or does it require a new one
Modified by HotChick at 5:48 AM 2/9/2004
Old Feb 9, 2004 | 10:19 AM
Elvis1977's Avatar
Default Re: 2000 accord check engine light (HotChick)
You probably need a new egr valve, and use new gasket.
Old Feb 9, 2004 | 11:11 AM
jweller's Avatar
Default Re: 2000 accord check engine light (Elvis1977)
there is a TSB out for this. and I think honda extended the warranty on this item. check with your dealer and http://www.v6p.net
Old Feb 9, 2004 | 12:29 PM
The_Todd's Avatar
Farts in the shower
Default Re: 2000 accord check engine light (jweller)
And also if you haven't registered with http://www.honda.com all you do it type in your vin # and BAM they will mail you maintenance interval coupons, recall info etc.....very helpful and reminding.
Dogman_1969
Aug 8, 2013 08:27 PM
clu2010
Jul 27, 2010 09:01 AM
litalang
Nov 10, 2004 10:11 AM
Goodhue911
Oct 31, 2004 07:17 AM
