Wheel cleaning help
Old Oct 8, 2001 | 12:13 PM
The Kernel's Avatar
Default Wheel cleaning help
I posted this in the Appearance / Cosmetic forum but got no responses so...
I just picked up a set of 3 used Mazda Millenia wheels from the junk yard for $300 and I'm going to use them for winter rims. They are hideously filthy and a bit beat up. I've cleaned an initial layer of brake dust off with Castrol wheel cleaner but they're still fairly dirty. Can anyone recommend a better more powerful cleaner?
Also there's some rust/corrosion where the hub met the wheel. What's a good effective way to remove this? Maybe just sand it down?
Old Oct 8, 2001 | 12:16 PM
The Professional's Avatar
New User
Default Re: Wheel cleaning help (NBP #0933)
You can only clean it off so much... some of the brake dust is literally baked into the wheel. The only way to get it off is by chiseling. As long as the outside is clean, just leave the inside dirt. Also, to get the rust off, just use some WD-40 and 1000+ grit sandpaper. Afterwords, you need to spray it with either colored paint or clear coat. G'luck.
GoLowDrew
Paint and Body
Aug 12, 2014 11:20 AM
lankan-balla
Paint and Body
Jun 26, 2013 06:54 PM
PowerLeg
Jul 3, 2010 11:17 AM
thawley
31
Mar 15, 2006 07:29 AM
The Kernel
Oct 11, 2001 04:08 PM
