gsr seat rust
Rust removal is best done with a wire brush, to get rid of the debris.
An application of phosphoric acid (the active ingredient in Naval Jelly) will seal the area and stop the existing rust from continuing its process.
If the rust has progressed so far as to weaken the metal, then you need to replace the parts or try to re-weld them.
